It is not receiving the test brake switch signal but the ecu is. The connection is after the coupling station on the bulkhead (after t11c/5)
The wire goes to the esp connector at t38/8 and the connection is D101 marked as "Connection 1 in engine compartment wiring harness"
Where do I find that connection ? Here is a picture of the wiring
Thanks!
