Hello, how are you? I wanted to see if someone could guide me or help me with a problem I have with VCDS, the reverse camera, and reverse sensors.
My Polo doesn’t have a factory-installed reverse camera or reverse sensors. Over a year ago, I installed a reverse camera that comes out of the rear door logo. Everything worked fine, and it appears on the screen. I didn’t have to modify anything in VCDS when I installed the camera.
Right now, I’m trying to install the 8K module for the reverse sensors. I’ve already done the installation, but now I’m dealing with VCDS. From Module 19 – Gateway → Installation List, I installed 10 – Park/Steer Assist. But when I do this, the camera stops working; nothing shows on the screen (When I put the car in reverse, I can hear the camera activate/open)
I can hear a beep from the sensor horn, but still nothing appears on the screen.
If anyone has had this problem or has any idea for a solution, I would really appreciate it.
VCDS, Camera and Parking Sensors
Re: VCDS, Camera and Parking Sensors
Hi, in addition to activating module 10 in the GW installation list, you must, through coding or adaptation (depending on the type of module 10 installed), tell module 10 if you have RVC installed.
Auto Scan? or info of the installed module...
Hi Ciclo, thanks for your help. I managed to get the sensors working, they now appear on my car’s screen. The only thing left is to make the camera show up. The camera I have is one I bought on Aliexpress; it connects to the reverse light of the taillight and sends the video signal through the typical yellow RCA cable. The parking sensors are also from Aliexpress, but those do come with a module that I connected to the car’s cluster. I’m also sharing the autoscan I did with VCDS—if you need anything, could you let me know how to get it?
AutoScan
AutoScan
Monday,15,September,2025,14:30:16:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WVWAU46R3DY251950 License Plate:
Mileage: 82670km-51368mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 08 09 10 15 17 19 22 25 2D 44 56
VIN: WVWAU46R3DY251950 Mileage: 82670km-51368miles
22-AWD -- Status: Cannot be reached 1100
2D-Intercom -- Status: Cannot be reached 1100
56-Radio -- Status: Not registered 0011
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 HE HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 4037
Revision: --H10--- Serial number: CVN: 4F805CB1
Coding: 001900D6200400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070HE 004006
VCID: 6CD771B7878BFEF307-8038
VINID: 9E69D19441A20D4A4214124500C1071406
2 Faults Found:
6056 - No Communications with HVAC Control Module (J301)
U0164 00 [040] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 67
Mileage: 82515 km
Date: 2025.09.15
Time: 00:15:05
Engine RPM: 862.00 /min
Normed load value: 4.7 %
Vehicle speed: 0 km/h
Coolant temperature: 75 C
Intake air temperature: 37 C
Ambient air pressure: 950 mbar
Voltage terminal 30: 11.374 V
Time since engine start: 2.7 s
Engine torque: 22.68750 Nm
Accelerator pedal travel-Accelerator position: 0.00 %
Ignition angle of current cylinder: actual value-Ignition angle: actual: 1.500
6443 - Power Supply Terminal 30
P1602 00 [032] - Voltage too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 1
Mileage: 82675 km
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Coolant temperature: -40 C
Intake air temperature: -40 C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
CTR_RST_MC: 0
CTR_RST_MU: 0
Ambient temperature: 20.25 C
Engine torque: 0.00000 Nm
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 AQ HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0003
Serial number: --------------
Coding: 20DD2885222800C1041D146E445100000000
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 0D111C33DC5157FBB0-8058
2 Faults Found:
0983 - No Communication with Instrument Cluster
U0155 00 [008] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 126
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
0885 - Immobilizer Control Module
U0167 00 [008] - No Communications
Fault Priority: 2
Fault Frequency: 1
Reset counter: 126
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 397998E3B0599B5BCC-806C
5 Faults Found:
01336 - Company Data Bus for Comfort System
014 - Defective - Intermittent
Fault Status: 00101110
Fault Priority: 6
Fault Frequency: 148
Reset counter: 126
Time Indication: 0
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 3
Reset counter: 126
Mileage: 82515 km
Time Indication: 0
Date: 2020.02.06
Time: 00:13:43
00532 - Supply Voltage B+
Fault Priority: 3
Fault Frequency: 1
Reset counter: 109
Mileage: 82515 km
Time Indication: 0
Date: 2020.02.06
Time: 00:13:43
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory - Intermittent
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 126
Mileage: 82675 km
Time Indication: 0
Date: 2020.02.06
Time: 00:01:48
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 126
Mileage: 0 km
Time Indication: 0
Part No SW: 6R0 937 087 M HW: 6R0 937 087
Component: BCM PQ25 H+4 H32 0407
Revision: BF032001 Serial number: 0540 082131159
Coding: 3DB02BBF08E32400923808003C2B0CD00040410F60040000200000000000
Shop #: WSC 124697 483 00190
VCID: 479DEE1BF6ADFDAB4A-8012
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU011031300010593
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU014031300013096
Coding: 18BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Serial number: 2961514284801372AA2B
Coding: 250000
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU012031300017984
Coding: 18BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU012031300012804
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 56D 919 475
Component: PARKHILFE 8K H02 0106
Revision: -------- Serial number: 35831415802218
Coding: 100001
Shop #: WSC 00081 790 00133
VCID: 3B7582EBB265A94BDE-806E
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Component: VW10Airbag00E H10 0020
Revision: -------- Serial number: 003GW00HTPB4 Dataset Number: v00304816R0 0001
Coding: 003045
VCID: 4999E823E8B90BDB5C-801C
2 Faults Found:
12670208 - Databus
U1122 00 [008] - Implausible Message
Fault Priority: 6
Fault Frequency: 1
Reset counter: 126
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
12674816 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 126
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Part No SW: 6R0 920 860 K HW: 6R0 920 860 K
Component: KOMBI H05 0605
Coding: 140A00
VCID: 3C7781F7B76BAE73D7-8068
1 Fault Found:
12653568 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 207
Mileage: 81683 km
Date: 2025.04.01
Time: 11:09:11
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H32 0407
Revision: BF032001
Coding: 002200
VCID: 70EF65C7A3A31A133B-8024
3 Faults Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
01324 - Control Module for All Wheel Drive (J492)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 86
Mileage: 82675 km
Time Indication: 0
Date: 2020.02.06
Time: 00:00:53
02065 - Control Module for Speech Amplifier (J656)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 86
Mileage: 82675 km
Time Indication: 0
Date: 2020.02.06
Time: 00:00:05
Address 22: AWD
Cannot be reached
Component: IMMO H05 0605
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADB77AF8D7FE0C375-803E
Address 2D: Intercom
Cannot be reached
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 10150
Shop #: WSC 00788
VCID: 306FA5C7F7235A137B-8064
1 Fault Found:
00566 - Steering Assistance Operation
27-10 - Implausible Signal - Intermittent
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5814
Revision: -------- Serial number: VWZZZ4H6290655
Coding: 1E000400040005
Shop #: WSC 127395 840 08317
VCID: 4683E31FF1A7E4A3B1-8012
5 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 58
Reset counter: 86
Mileage: 81804 km
Time Indication: 0
Date: 2019.08.28
Time: 13:39:41
Fault Priority: 3
Fault Frequency: 9
Reset counter: 40
Mileage: 82515 km
Time Indication: 0
Date: 2020.02.06
Time: 23:24:19
Fault Priority: 6
Fault Frequency: 22
Reset counter: 126
Mileage: 82515 km
Time Indication: 0
Date: 2020.02.06
Time: 00:03:56
Fault Priority: 3
Fault Frequency: 2
Reset counter: 126
Mileage: 82540 km
Time Indication: 0
Date: 2020.02.06
Time: 22:29:10
02873 - Control Module for Back-Up Camera (J772)
Fault Status: 00110100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 126
Mileage: 82675 km
Time Indication: 0
Date: 2020.02.06
Time: 00:03:17
End-------------------------(Elapsed Time: 03:28)--------------------------
Basics for VCDS or any other diagnostic tool:
- AutoScan or Clear all DTCs: IGN ON, ENG ON. (in most cases)
- Any other diagnostic procedure such as coding/adaptation/flashing, etc.: IGN ON, ENG OFF, and turn off all battery-draining electrical devices such as lights, radio, A/C, etc. The battery is not an infinite resource!
Correct the GW installation list in module 19.
- You must check or uncheck the modules that are or are not installed in your 6R.
- In your case: uncheck addresses 22 and 2D, and then check 56. Save.
Address 10:
- Verify Adaptations: Visual display for Park Assist - Rearview camera.
- New coding: 308001 (security access is required, enter -71679- before coding)
Address 56:
-Code correctly. The label contains the bit descriptions you should mark according to your vehicle's equipment.
eg:
Verify all Bytes! ... (graphics-6R)
New Autoscan:
Autoscan, GW installation list, Clear all DTCs, Done. Start new autoscan. Save.
Address 10:
Address 56:
eg:
New Autoscan:
You may need to RESET the radio or perform a new ignition cycle, or both. (RESET: press the on/off or MENU button on the radio for 10s)
I don't know the exact procedure for 'this radio' to make the changes take effect.
