Exhaust cam variator. Loose / missing bolts
GE-818
Drives: Match
Re: Exhaust cam variator. Loose / missing bolts
Post by GE-818 »
TTRACES55 wrote: Sat May 07, 2022 10:19 am If you want to post an email address (create one if you don’t want to publish a regularly used one), I’ll send you the pages from ErWIN. You can see the pictures / info that VW uploaded.
Hi, is there any chance you can email me the ErWin documentation for TPI 2055431/4 ?
I have the exact same issue with my 2019 Passat GTE which has the 1.4 TSI engine ( exhaust camshaft adjuster bolts loose )
It seems that private individuals no longer have access to ErWin
My email is [email protected]
Thanks in advance!
