2016 polo Gti rear suspension struts / shocks
Discuss Suspension, Brakes, Wheels and Tyres
APgti
Drives: Polo Gti 2016
Post by APgti »
Can anyone tell me the part number for rear suspension struts as mine are leaking. Or even an oem alternative?
NatalieGilmore
Drives: mazda
Re: 2016 polo Gti rear suspension struts / shocks
Post by NatalieGilmore »
This post brings back memories of my own suspension woes! My old car developed a similar leak, and finding the right part was a real headache. I ended up scouring forums and even calling the dealership directly, only to discover a slightly different OEM option that worked perfectly. It's a frustrating situation, but definitely fixable with a bit of research. While you're pondering suspension, maybe try a round of Heardle for some musical fun.
xadomik
Drives: s3
Post by xadomik »
Before choosing any platform, I usually read reviews, check how long it has been operating, and see what kind of facilities it offers. Country Club Casino, for example, has been around since 1982 and is part of a larger resort complex, which often indicates stability and proper management . Doing this kind of research helps avoid unreliable choices. If you're considering platforms or venues in Australia, always prioritize those with a proven track record and transparent operations.
Sam Kirk
Drives: 2013
Post by Sam Kirk »
This is a common issue, and it's always best to address leaky struts sooner rather than later to prevent further damage. I'd definitely recommend checking forums specific to your car's make and model – sometimes even a quick search for Granny-approved suspension fixes can lead to surprisingly helpful DIY guides and part numbers from fellow enthusiasts! You might find that OEM parts aren't the only reliable option.
