Polo 1.2 6R CGP Engine rebuild
UKWaffles
- Drives: Polo 1.2 6R 2009
Re: Polo 1.2 6R CGP Engine rebuild
Yea, was using my breaker bar so I suspect the flex there might have taken some of the power out of the turn.
Its such a small leak as well, doesn't do it for like 20 seconds after starting the slowly seeps out and stops after about a minute.
Spot on! A long breaker bar will flex like a bow under that much load. You think you moved the handle 90 degrees, but the socket itself might have only turned 75.
That 20-second delay is just the oil pump building up full pressure to the top end, and the 1-minute stop is the aluminum heating up and pinching it shut. It's a sign of just needing that tiny bit of extra clamping force.
Give that breaker bar a good, solid nudge to compensate for the flex and let us know if it seals it up.
UKWaffles
Yea will give it a go, its the last "major" leak now once this is fixed I can get it checked over for a MOT and get it driving if it doesn't need welding.
Has a had a lot of welding done in the past and I quite like the shape and wanted to give it a crack,
My 130i is my daily so this is a side project / wife car if it gets passed and lives long enough. Only errors on the dash are for a bad battery.
£480 on parts so far including the head rebuild so got some time and leeway.
Been fun so far.
Been fun so far.
That’s the best way to do it! Having a 130i as a daily means you have zero pressure. Side projects are always the most fun because the only deadline is the one you set for yourself.
For £480 including a full head rebuild, you’ve done an amazing job and still have plenty of leeway. Clear that battery code, give those bolts the extra nudge, and hopefully, it passes the MOT with flying colors without needing the welder this time.
Keep enjoying the process, that's what wrenching is all about!
UKWaffles
Yea, getting there.
Easier to work on than the 130i as well, more space for all activities
UKWaffles
Although I have now remembered how much has to come off to get to the head bolts....
RIP, there are so many torque to yeild bolts on these cars.
Big ones are Crank and cam bolts.
That's the beauty of doing it yourself... thankfully we aren't robots on an assembly line anymore and can take our time to do it right.
Good luck with the teardown.
UKWaffles
Yea, I'll crack on in due coruse
Though technically its only the crank bolt I need to undo and replace the cams can stay on, so that's fine I guess..
The bolts for the camshaft carrier will be annoying though, won't need as many I guess this time around as I don't need to undo the camshaft caps themsevles.
Either way wait to payday for some parts to get ordered.
UKWaffles
Well getting back onto the polo project
Got the engine stripped down and did the head bolts a smidge more.
Then saw this on the timing cover...
Seems the oil pump chain and cam bolts have contacted the cover.
Not sure yet as to why as they are all tight so maybe I over did the cover?
- PXL_20261104_155039015.jpg (2.42 MiB) Viewed 4018 times
- PXL_20261104_155043396.jpg (2.28 MiB) Viewed 4018 times
Whoa, good catch spotting those marks before buttoning it all back up! Those are some heavy scoring marks on the aluminum.
Over-tightening the cover wouldn't cause this, as the cover seats metal-on-metal against the block.
This contact actually links back to our original alignment mystery.
- If the head is still slightly offset or sitting a fraction of a millimetre too far forward on the block, it pushes the entire camshaft and timing gear assembly closer to the front cover, causing the bolts and chain to grind against the inside wall.
- Double-check that all thrust washers or spacers behind the cam gears and the oil pump gear went back in the exact correct order. If a gear is flipped backwards or a washer is missing, the gears will sit too far out and shave the cover.
Since you have it stripped down, make sure the head is perfectly dropped into its dowel pins so the valvetrain aligns with the cover.
Edit:
Download this PDF in case you need to look something up.
3-cylinder injection engine (1.2 l engine, 4V, EA 111)
Edit:
UKWaffles
Yea, I suppose its all down to the head allignment.
There is not too much metal around in the engine from what I can see, the filter has some. Hope its not done too much to the engine while I decide what do moving forward.
It all looks to be in aligned as the head is not proud of the block but I guess its only millimeters here, so I need to order some new head bolts and get that sorted while its stripped down I guess.
You hit the nail on the head. In engine building, our eyes easily miss what a fraction of a millimeter can do.
Just 0.5mm of misalignment, which is almost invisible to the naked eye, is plenty to cause a head gasket weep and make a spinning bolt shave the aluminum cover.
Don't panic too much about the aluminum flakes in the filter. That means the oil filter did its job perfectly and stopped them from reaching your bearings. Since aluminium is a soft metal, it's much less dangerous than steel, but definitely flush the oil and drop the pan to clean it out before the final start.
Ordering those new head bolts and resetting the head onto its dowel pins using the manual is 100% the right call. You are doing a proper, thorough job here.
Good luck with the reset, you're almost at the finish line!
UKWaffles
Yea, got them ordered now so once they arrive I will take the head off the engine proper this time and check the dowel pins.
Learning a lot from this and not too bad overall, car is on 110K miles and is decentish shape overall bar the fact the timing guides went on the origional issue to kill the engine.
Ran quite nice when it did breifly, didn't see anything in the head / cams for the timing cover shavings so new filter to go in and oil to clean it. Need to check the specs on the oil pump chain and such as it seemed a little loose for my liking so might do that while I am there type thing.
Plan eventually is a cheap run about car for the wife.
This is exactly what wrenching is all about! Honestly, these are the best projects, the ones that teach you the most, test your patience, and end up being a reliable, cheap runabout for the family.
When your wife drives it, you’ll know every single nut and bolt in that engine is perfect because you built it.
You are making a great call checking the oil pump chain. Since the original timing guides failed and likely dropped debris, that chain could definitely use a quick inspection or replacement while the cover is off anyway.
Take your time with the alignment dowels and enjoy the process. You are doing an amazing job turning a dead engine into a proud family savior.
Keep us posted on Round 2, you've got this!
UKWaffles
I am guessing the head being to far forward would push the oil pump chain out of placement, though could also be the gear is on backwards.
Need to see I guess never did hear any odd noises when it was running though engines are noisy things anyway so prob covered it all up
There a way to tell if the oil pump gear is on the wrong way, there wasn't much seemingly keeping it in place bar the pressure from the crank bolt
