HEAD UNIT WIRE COLOURS
Discuss In Car Entertainment
RICHARD HARPER
Post by RICHARD HARPER »
Does anyone know what colours the Front Left & Right Speaker wires and the Rear Left & Right Speaker wires are on the wire harness going into the standard ISO Connector ?
I've got an amp & sub to go in but need to disconnect these from the ISO Connector as i'm uprating the wiring and speakers
sylonien
2nd Stage Warning
Post by sylonien »
Well depending what model you've got, you might not have the wires for the back left/right speakers.
If you look at the two ISO plugs, you should find the top one with like 5 wires connected to it, either brown or black the actual plug. That's the one for power, ground, etc.
The other one should be than the speaker one, if you just have the front speakers then you should be able to see it having 4 wires connected to the centre.
Quite confusing if you don't know what I'm talking about - sorry! :lol:
RICHARD HARPER
Cheers managed to suss it out.
