Please Help!! My Polo Keeps Stalling When Coming To A Stop!!
Discuss Engine, Gearbox and Exhaust
the_muff2004
Post by the_muff2004 »
Hey just new to the forum first post! i just bought a vw polo 1.4cl r reg last week. over the last few days though ive noticed that when im coming to a stop the rev counter dips down below the 10 when i put my foot down on the clutch and is causing the car to stall! it aint happening all the time! but at least 3 times per journey! any ideas on whats causing this!! and if i can fix it myself! or is it a garage job!!??
cheers in advance for ure help!
dubpolo
Sponsor
Post by dubpolo »
temperature sensor has gone! the part will cost you about £14 and then they will charge you one hours labor
metz
Moderator
Post by metz »
Mine was doing same and the blue temp sensor is ok, i cleaned the throttle body out with wd40 (all i had at the time) and its been fine since.
dubpolo
Sponsor
Post by dubpolo »
there you go then! try cleaning your throttle body!
the_muff2004
cheers for the help! sorry not to great wi cars were is the throttle body? and how do i clean it??
cheers again.
metz
Moderator
Post by metz »
its under the airbox (the thing the airbox connects to) and i just sprayed wd40 all over it and cleaned it with my finger *probably not professional way to do it* then cleaned the butterfly in the bottom too. it was all dirty and oily but after was shiny.
carmadaaron
Post by carmadaaron »
yep definately the throttle body.....
but ive been told b4 that, its a sign it might need a new 1 soon..
the_muff2004
.gfh
the_muff2004
cheers for the help!! does the throttle body have to be removed to clean it! cause it looks like it could be quite a tricky task!
cheers.
metz
Moderator
Post by metz »
I didnt remove mine but i was rather fiddly.
the_muff2004
thanx for the help im giving it a try 2morrow so ill let u know how i get on!
cheers.
Tahrey1043
Post by Tahrey1043 »
so the throttle body is the bit ABOVE the butterfly valve, that the injector is bolted to --- not the part of the intake immediately beyond it?
*has been squirting the wd40 and cleaner in the wrong bloody place all this time*
*no wonder the car runs like a mule*
the_muff2004
hey just tried to find it but i cant locate the throttle body! heres a pic of my engine will i have to disconnect the airbox to get to it??
metz
Moderator
Post by metz »
yea, its underneath the airbox...I'm glad my car hasn't got the engine cover on..looks really fiddly!
Tahrey1043
yay! so i can just pop the binlid off and set-to with the cleaning spray?
