polonuts wrote:I have got a slight problem with my MK3 1.0 squareback. The fan doesn't seem to cut in at all and the engine overheats badly.
Checked the fuse?
Assumes you've done that
OK first check the fan works - trace the power lead - disconnect and then with a couple of lengths of wire (crocodile clips on each end) ground one to the chassis and connect to one terminal. Connect the other to the remaining terminal and touch on the battery Positve terminal (if negative ground)
OK at this point the fan should spin or its FUBAR
FUBAR means replacement required
If it spins then something it telling it not too or not telling it too
Next step find the temp sensor -
sorry don't know where it is but a MKIII owner will
Once you find the sensor and with the fan you know works un plug the lead to the sensor and connect the two terminals in the plug the goes to the sensor - with ignition on the fan should again spin
If it does - replace the sensor it's FUBAR
If it doesn't then life gets fun!!!!!! Cos you will probably have a wiring fault somewhere so you are looking at running a new feed or finding the fault
polonuts wrote:The other problem is that my car heaters will not blow hot air into the cabin.
The heater fan doesn't run at any speed or the heater fan runs but only get cold air?
polonuts wrote:Are these related problems or is the heater matrix dead along with the thermal switch for the fan??? Please help if you know the answer as I do not want to change items unescessarily.
Unrelated IMHO but looking forward to a bit more detail
polonuts wrote:Oh by the way my accelerator pedal is sticking quite badly as well, the revs will shoot up to red line when I put my foot in on the clutch and I have to physically pull the pedal back up with my foot to reduce the revs. Any ideas for this problem as well
This ones tricky
Sounds like a spring missing or seized cable
Disconnect throttle cable on carb or throttle body in engine
Does pedal still stay down and is it free and easy to move cos if it does stay down it's normal but if it's stiff to move it's not and thats why the spring on the other end of the cable is struggling to return the pedal
This may be Cable frayed inside or as previously suggested a missing or broken return spring on the throttle body or carb
Bout it for me
