Springs
- bstardchild
- Moderator
Re: Springs
Easy job - if you've done stuff like this before - not so easy if you haven't - you can get things horribly wrong with camber as a result of unbolting the bottoms of the shocks.......mikhal_fi wrote:anyone have a DIY guide to fitting springs to a mk5??Or have any tips?cheers
I don't want to be patronising but take it to any fast fit centre and it will probably be fairly cheap and done well..
If you are really burning with ambition to tackle it yourself PM me or say here and I'll do my best to try and point you in the right direction
The biggest problem will be buying spring compressors and the right size torx bits and sockets and breaker bars to get it all undone - by the time you've bought all that it's cheaper to get someone else to do it........
You aren't local to me either so I can't help out
