Central Locking Pump - Harness Pinout??
inder
Post by inder »
Im trying to splice in a remote central locking kit, and thought the best place to get connected to the cars wiring would be on the harness that connects to the central locking pump in the boot - thing is i can't work out which wire does what, anyone have a pinout for it??
Wiring on harness is as follows, each pin is numbered as: [VW POLO 1.4, W - 2000]
1 - Red/White (thick wire)
2 - Red/White (thick wire)
3 - Brown (thick wire)
4 - Red
5 -
6 -
7 - Yellow/White (with a small Black Stripe at end)
8 - Brown (thick wire)
9 -
10 - Green/White
11 - Yellow/White
12 - Black
The central locking kit is the '6139' by Gemini and has (colours they use in brackets):
Earth (Brown)
Battery +ve (Red and White/Red)
Ignition Live (Yellow)
Direction Lights (Orange)
Positive Alarm Armed (Pink)
Central Door Locking Control (Yellow/Grey, Red/Grey)
Common for Door Locking Signal (Yellow/Red)
Thanks in advance for any help or advice! :D
inder
Post by inder »
or any advice on where to find the wiring elsewhere? :(
inder
Post by inder »
ahh well :(
James0121
Post by James0121 »
hey up
I had mine done when the guy put my alarm in which he mounted the unit up near the fuse box.
Im not sure if ne1 on here has put there own remote locking in. I guess we will see.
sorry not much help
James
inder
Post by inder »
Thanks m8
Thing is I don't wish to have it running off an alarm at this stage, I know that could be the best route etc... (car has no alarm, has coded key immobiliser) but the kit I have just converts the key lock into remote with a nice small button for your keyring
Im taking the door card off tomorrow for something else, so may try see the current wiring to find out which wire is the 'open' signal and which is 'close' etc... somehow hehe
James0121
Post by James0121 »
awww right.
Dont suppose the haynes manual is any help for this ?
inder
Post by inder »
hopefully, im waiting on haynes to get the latest book back in stock for the polo - it just recently got printed and is out of stock
:lol:
AKs_SlickPolo
Post by AKs_SlickPolo »
Hi, im trying to fit a remote keyless entry kit as well. I was told that the central locking pump harness is the best place for this. Correct me if im wrong but you need 12v power, earth, and + close lock and -open lock wires to make it work. (something like that anyway) trouble is the wires which is which. let us know or post a message here if u figure out what each wire is on the central locking pump harness.
david burton
Post by david burton »
Hi mate,
did you succeed at this in the end?
AKs_SlickPolo
i havent bothered yet :( but i am told that an extended negative pulse has to be used, which means hooking the wires up to the wires behind the glovebox!!!
inder
Post by inder »
I gave up splicing in too, too many colours to work out what and im impatient lol
So I installed a Votex remote unlocking kit, that also does the flashers with autoclosure 8)
david burton
any details of the votex kit mate? and prices?
inder
Post by inder »
check: http://www.vagparts.com/pages/MK3Golf.htm
in the mk3 Golf section under electrical the kit listed there will fit the polo price £89.85 +vat UK shipping £7.19 at the time
really easy, simply clips in-between the pump and factory wire loom/harness, then put the aerial lead across boot and add the optionial flasher wires in, easy to find the colours on the rear clusters, but splicing the cable in was fiddly, not much factory cable to play with, but possible and works fab
hope helps
