[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 flamin wheels - UK-POLOS.NET - THE VW Polo Forum
ive just put my g40 brakes onto my gt and now the pad carrier catches on the inside of my bloody wheel! i put a spacer on but this means the wheel isnt on the hub only the bolts! im really annoyed.
has anyone had this problem?
i was thinking of getting some p-slots, will they catch?
cheers
james
the G40 and GT pads are the same shape, but G40 pads are thinner, so you can either fit new G40 pads or use your old GT ones if they are worn down a few mm (but this is not recommended)
the pads i have put onto my brakes are different. there is a longer thinner pad and a fatter pad? will these work on the mk3 carriers or can i use my original pads from my standard setup which were fairly new?
big thanks to optima ive now sorted my brakes (well my front ones) but ive gotta do my rears now as my rear wheel cylinder pissed fluid everywhere! cheers mate
