[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 100oC normal? - UK-POLOS.NET - THE VW Polo Forum
hi my car has been running about 100oC on average on the temp lately even on the motorway, the compression has been checked both temp senders changed, water drained and refilled, new rad, only thing that hasnt been checked is the water pump but that is getting replaced on tues. Any ideas?
should run at about 90. DO NOT WASTE YOUR TIME with a wax thermostat that isn't VW. I had 4 different ones including halfords and they were all useless until I got the proper one from VW, which worked perfect. VW parts are not expensive when you consider the effort involved in draining and refilling and bleeding it again.
It does sound like its just over-reading. If the fan comes on after a few minutes and then goes off again, then I wouldn't worry about it. Just check that your oil and water are not getting contaminated.
Quite sure its the gauge over-reading, because of what he said about the fan coming on at 110. It should be on at about 100. Even when pressurised, the coolant will boil at 110.
