[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 can i fot mk2 golf brakes on to me coupe s - UK-POLOS.NET - THE VW Polo Forum
I want more power in me coupe s mk2 expect i know that the brakes wont be able to handle it, and will get to hot
I know i can have groved and drilled disk, but i was wondering if i have the mk2 golf fronts brakes and capillars on me car, and is it poss to fit a servo on to me car?
x
Ps i have the bits already just need to know if they will fit
Give them a try on your existing carriers then.. I got the carriers as well just in case, but I've never got round to fitting the brakes anyway..
The callipers have to be off a GTi or there's no point in changing them, the normal golf callipers are VW I just like the polo ones.
Shouldn't be too hard to get them off.. callipers are held on with two 6mm allen bolts, just remove them and pull it outwards from the centre of the disc from the bottom of the calliper. The disc then just unscrews and pulls off the hub. Shouldn't really take more than a few minutes, and I'm pretty sure it'll be worth the effort
