problems with polo starting...
tj
Post by tj »
Hi
Just bought a polo 1.6 CL. Im having problems whenever starting.
When starting up it requires a bit of gas it revs up but then just drops.
To get around it I rev it for over 20 seconds and it was ok. Idling was fine.
Does anyone have any ideas?
Any answers would be much appreciated.
cheers
TJ
waseem0000
Post by waseem0000 »
maybe u have to clean the injection ! :idea:
ste mk1lx
Post by ste mk1lx »
I don't know the answer but if you bought the car from a garage then they should fix it (sale of goods act)
tj
Post by tj »
cheers for the reply
got the car off someone i know knew it had the problem but hadnt investigated it any further.
I think im going to put some fuel injector cleaner. Also gonna get the ecu checked see what the outcome is.
cheers
bstardchild
Moderator
Re: problems with polo starting...
Post by bstardchild »
tj wrote:Hi
cheers
TJ
Sounds like an air leak on the induction side
tj
air leak?
Post by tj »
I noticed this morning when it warmed up the revs are ok just needs warming to get the idling ok. Would this still be caused by an air leak??
if so where do i start checking for air leaks?
sorry just a newbie to this.
cheers
TJ
tj
starting up
Post by tj »
I have put injecter cleaner through the car. Car seems slight better in the morning the revs sort themselves out a bit more quicker.
but have to give it gas to start up.
any ideas what i can check now???
