changing pedals ???
1litreheater
changing pedals ???
Post by 1litreheater »
Sup guys, my mate has given me a new pair of racing pedals that he doesnt need and i looked to fit them on to my 6n today and i have got any holes to bolt thru ! will i have to make some by drilling thru my self or is there an easier way to put them on ! cheers :?
andythebubble
Pedals
Post by andythebubble »
Well, I had to drill holes into my pedals, but dont worry, its very easy. Just follow these tips and you'll be fine.
1st) Make sure you have a metal cutting drill bit, other than the normal ones, will just blunten and burn up.
2nd) Mark up on the pedals where you are going to drill these holes. Make sure they are evenly spaced and wherever you drill, that it hasnt got anything obstracting e.g. support bar.
3rd) Then Put blocks of wood behind the pedals, to give them support, and if you want use a centre punch to leave your mark, and then drill away, if you can slowly.
