Door glass
Chat about your MKI or MKII Polo (86 and 86F)
dpm
Door glass
Post by dpm »
My young sons Mk2 polo drivers door glass was smashed last night, does anyone know if the glass from a later model will fit ? before i do a tour of the local breakers.
Gareth_GT_Hatch
Re: Door glass
Post by Gareth_GT_Hatch »
dpm wrote:My young sons Mk2 polo drivers door glass was smashed last night, does anyone know if the glass from a later model will fit ? before i do a tour of the local breakers.
you may need to swap the rubber seals around but otherwise it should be ok. There are some mk3 coupes that have flush fitting windows - you need to avoid these as they wont fit (i dont think) unless you keep the rubber that they come with.
dpm
Post by dpm »
Thanks for that but it's the main window that winds up and down that got smashed.
metz
Moderator
Post by metz »
i have the drivers and passenger glass in my shed off a mk3 saloon (would that be the same anyone?) if you can't find any let me know.
dpm
Post by dpm »
The car is a coupe don't know if the doors/windows are the same as saloon .
Gareth_GT_Hatch
the windows that wind up and down are all the same. Only thing is some are tinted and some arent.
GroovyCarrot
Sponsor
Post by GroovyCarrot »
The front end glass is all the same really between mk2 and mk3.. the rear end glass I believe is the same for coupe and saloon models but I don't think it's the same between mk2 and mk3s.. or something like that. Certainly the front drivers window will fit though.
Gareth_GT_Hatch
the normal side windows and windscreen are all identical on mk2/3 coupes and saloons. Obviously the hatch has the long rear window...
