WTF?! Just noticed that my 1.4 16v doesn't have fog lamps!
david burton
Christian6N
mk4ads
Yep
I'm sure the grilles already has the cuts out in for retro fitting of fog lamps, If not you will need to get the 2 small plastic grills that hold the fogs which are about £20 I think then fog lamps themselfs are about £50 quid each I think!
Sorry I got it the wrong way round you pull it out once for front fogs then out twice for both, so if you wanted to use just ur front fogs (for showing off
) then you would need to buy the 2 pull switch.
The wiring should already be there being a 16v so It's just plug and play really
david burton
Christian6N
No sorry, there is no plug and play guys.
And i know what i am speaking of.
You need the whole wireloom for the complete front, i mean from the connector above the watercooler to the foglights (two wires). That´s for sure.
And then it is a question of good luck if your car has the one wire from the lightswitch to the centralelectricbox and from the centralelectricbox to the connector above the watercooler.
Right Alex?Wasn´s it that way then? long time ago right?*hmpf*
So if you realy are interested on this wait till i am back from the wörthersee next week, then i can tell you what to do to find out which wires you already have.
Christian
Christian
