Please help so I don't need to brake it
Cockpit removal
Cockpit removal
Has anyone ever removed cockpit on polo mk1. I removed all screws, wires, everything, but it won't come off like something is holding it right at the top, near the windshield.
battery is removed, heating system also
what is bulkhead? fusebox?
perhaps you could take these two pictures and mark where are these nuts located, although I think I removed them all, because I can lift the cockpit very high (like "rotate" it round it's very top end where something is still holding)
please don't comment car's condition
can you email the picture at [email protected] sorry if I'm bothering you too much
you have done this before and it came off easily then?
I looked for those two bolts you said and it came out that I removed them already just as I supposed, didn't have time to remove the plate holding fuses though, but I doubt that's what's holding the cockpit because as I said alredy I can "lift" it very far up but there is something still holding it at its' very top near the windshieldste mk1lx wrote:your welcome hope it is of some help to you, you should post your pictures of the mk1 on here (the one that are on club gti) good luck with the project
how did you remove it, pulling it towards where?
