scrapyard engine id
Chat about your MKI or MKII Polo (86 and 86F)
steveo3002
scrapyard engine id
Post by steveo3002 »
im going to trawl some scrapyards for a 1.3 polo , as they dont have a engine size on the boot, is there a easy way to tell the engine size?
i assume its cast onto the block somewhere but theyre usually caked in grease
ste mk1lx
Post by ste mk1lx »
if its the mk2 it is easy to spot the 1043 has a vacum valve on the bulkhead the 1272 doesn't.
mk2keel
Post by mk2keel »
Also the engine code will be stamped on the bottom left hand side of the block (might have to wipe it clean but it'll be there)
The 1.3 coupe S lump will have MH..... written on it
GroovyCarrot
Sponsor
Post by GroovyCarrot »
1.1/1.3 have 4-2-1 manifold/downpipe arrangement, 1.05 has a straight 4-1.
1.3 also has larger air filter housing than 1.05, and if it has a twin venturi carb then it'll be a 1.3.
Gareth_GT_Hatch
Post by Gareth_GT_Hatch »
GroovyCarrot wrote:1.1/1.3 have 4-2-1 manifold/downpipe arrangement, 1.05 has a straight 4-1.
The manifold is a 4-1 on my ranger. (its 4-2-1 on all mk3s and possibly 2G (late 1300cc) mk2s and the some HB engines (1100 formel E)) Later mk2s and all spi mk3s have the same air filter housing. It depends on the age of the car for these kind of facts though. Ideally the scrapyard will have information on the car, preferably the V5 which will have the engine number on it. Other things mentioned are not as easy to spot since most places I go to, the carb/dizzy is removed and stored elsewhere. There arent many clues to give the game away really! Only thing I can think of that will be pretty obvious is the inlet manifold part number. Should be visible on top of one of the channels: Heres a list of all the ~55bhp 1300cc engines which look more or less identical to one another (I assume thats what youre after?)
030 129 711 P 1300cc AAV Mk3 engine
030 129 765 G as above
030 129 711 N = late 1300cc mk2 (MH and 2G engines)
036 129 711 L = intermediate 1300cc mk2 (HK engine)
052 129 712 = early mk2 (and all mk1) 1300cc (HH engine)
Id assume these would be the most common ones (unlikely to find an NZ or GT engine, but then again youll know one of those when you see one.
Tahrey1043
Post by Tahrey1043 »
furthermore to the V5 having the engine number, shouldn't it also have the cubic capacity there as well?
as its been a part of car tax for the past fifty years or so after all..
Gareth_GT_Hatch
Tahrey1043 wrote:furthermore to the V5 having the engine number, shouldn't it also have the cubic capacity there as well?
indeed.
