Diesel
GroovyCarrot
- Sponsor
Diesel
Is there a diesel engine that is an easy fit to the mk2? Just starting to do more miles, economy isn't fantastic and I'm not exactly earning fortunes at the moment. Probably a silly idea, but it's worth a shot. Any of the old golf engines the right fitment, for example?
carmadaaron
Tahrey1043
- Location: Birmingham! Enjoys: The pseudo-G-Smiles provided by a 1.6 Megane Sport valver...
GroovyCarrot
- Sponsor
amstrange1
There was a diesel Mk2 and Mk3 Polo, but we didn't get them over here. Even if you did find an engine, you'd have to alter the fuel system etc. and it'd cost a fortune for the gains you'd be getting. Probably better off selling up and getting something else if you need better economy. Mk2 Golf GTDs might be suitable for you.
Tahrey1043
GroovyCarrot
- Sponsor
I'd have to change tank, pumps, wiring etc to convert it to injection too, so not much difference there, and if I was dropping in a new engine I'd be dropping in a gearbox at the same time anyway.
Still, guess it doesn't really make sense to mess around converting it.. just have to sell up if I can't afford it. Anyone know what a mk2 (or a mk1?) golf diesel does in terms of mpg?
Tahrey1043
GroovyCarrot
- Sponsor
GroovyCarrot
- Sponsor
Tahrey1043
let me just convert my polo fuel spreadsheet to something a little more cross-compatible than MSWorks and remove anything potentially embarrassing and you'll be able to see exactly what the economy's like
how are you driving it, though?
if you're really trying to be frugal and can only get 37mpg then you'd be as well to get an injection as a diesel as you'll potentially get 50% more miles for your money.
i'll say as i have before, even without looking at the sheet - i've only once had it below 30mpg even with concerted thrashing (well, ok, twice, but i don't trust the second one as it was immediately followed by a 60mpg even though the driving style was the same). Which suggests to me that you'll probably do alright from the swap, as those particular trips were spent either at 90mph or trying to acheive it.
ps The GTD was supposed to be a diesel GTi wasn't it? Suggests to me that if it got 75 brake, the rest of em had less... wonder where we could dig some figures from..?
(ah! parkers perhaps...... while you're waiting, have a gander at this for fuel economy's sakes
http://www.parkers.co.uk/choosing/user_ ... 6&id=14448)
edit: only diesel owner review that you might be able to afford one of is a GTD oddly enough: http://www.parkers.co.uk/choosing/user_ ... 039&id=722 - verdict --- reliable, frugal, and although deathly unresponsive it's reasonably pokey once it wakes up.
Other scratchy details (mostly garnered from tech specs on later models) suggest a 60 or 64hp base engine for the non turbo (which, if you assume - perhaps wrongly - that the earlier diesels were also 1.9s, holds true along the hp-per-litre lines compared to the 48hp 1.4D Polo), 75 for the GTD and 90 for the TDi...
(if it were, instead, say a 1.5 thru 1.7 diesel, you'd only be looking at 51 to 58hp... an improvement on 45, for sure, but with the larger car and much heavier engine all the benefit might get swallowed up, particularly with the acceleration/gearing disadvantage inherent to an old-skool, non turbo diesel)
Gareth_GT_Hatch
- Platinum Member
The mk2 golf GTD was a 1.6 litre Turbo Diesel and had 80bhp. The 1.9 suceeded this engine in the mk3 golf. There were a few different versions. There was a TD version that had 70 bhp (the difference between the TD and the GTD being an intercooler) and probably an NA one too but no idea what thats like (not good though I bet)
edit - just found out it has 54bhp!
You might see a few more mpg from fuel injection, 37mpg doesnt seem too bad to me though. Im still only getting around 30 from my mk2, but should get 40+ once its fuel injected. Hoping to have that all done in time for BVF so I can see how much better it is on a long run.
GroovyCarrot
- Sponsor
I got 40mpg on a motorway run, not really trying for economy but cruising around 70-75. 36-37mpg in daily driving (mainly the 15 minute journey to town and back again around the lanes), regardless of how I drive. Could be a tank full of thrashing it or a tank's worth of driving like an old granny and really trying to save petrol, it'll always be the same.. nice when I've got a lead right foot but annoying when I'm skint.how are you driving it, though?
I've just been doing some investigation on carfolio.com and parkers:
Mk1 1.6 diesel N/A:
50.0bhp (60.24/tonne)
IG unknown
Mk2 1.6 diesel N/A:
54bhp (58.7/tonne)
IG 9
Mk2 1.6 turbo diesel:
70.0bhp (76.1/tonne)
IG 9
Mk2 1.6 GTD:
(No record)
IG 9
Mk2 Polo 1.4 diesel:
48.0bhp (59.6/tonne)
IG unknown
Mk2 Polo 1.05 petrol:
45.0bhp (62.9/tonne)
IG 4
Annoyingly, no fuel consumption figures for any of them..
Looks like the golfs are going to be good and pricey to insure
