No speakers in back of 6n2
Discuss In Car Entertainment
PhilGTi
Post by PhilGTi »
How do get arround this?? Can you buy new rear door cards or something? I dont fancy cutting my current ones to fit speakers but its s**t with just front ones... I dont wanna fit any 6x9's or anything...
Phill.
inder
Post by inder »
m8 ive got rears in mine! perhaps cos yours is a diff model
anyway, yes a new door card will provide you with the cutout and grille too, but im not sure the speaker wiring will be present
but prob does not matter, as you will be laying new cable from an amp or something :wink:
I think the standard speaker sizes are not 17cm and you need an adaptor thing to put aftermarket ones on
is your interior black? I get these parts numbers, check with vagparts or dealer??
left, off black, 6N3 867 043 BJ 7WP
right, off black, 6N3 867 044 BJ 7WP
loudspeaker grille x2, 3B0 868 149 C81
p.s. you want a 'side panel' rather than a rear door card, otherwise the shape will be wrong for a 3door and you will have a hole in the top for the door lock etc..
Hope helps! :)
Randall
Post by Randall »
polosilver mate,
if you want rear quarters with speaker recesses you looking into the price of around £90 per panel as i enquired about this a while back!
i went nuts one day n yes i did it - cut sum nice 6.25" hole in the panel with mdf supporting rear panel n also seperated the tweeter just inside the arm bugle bit facing rear seats.
still need to tidy them up a lil bit as the speaker grille sint quite flush yet but should look mad once finished :twisted:
inder
Post by inder »
I can take a picture of my ones if it helps for marking up the cutout :shock:
Randall
Post by Randall »
I'll join inder on that one...i'll grab a pic to for ya later this evening just to show how crazy i went
be kind tho it isn't finished!
stuart_hatch
Post by stuart_hatch »
Try getting the door cards from a scrappy?
I did this on my peugeot 106 run around also the wirying should allready be there.
Randall
Post by Randall »
I'm not sure if it was just mine or if others have found this but when i installed my rear speakers there was no wiring present!
BUT its easy enough to put the wiring in place :D
stuart_hatch
Ah well, your probably better running new wire anyway.
hardhitter
Moderator
Post by hardhitter »
Don't bother, spend the money upgrading / amping the fronts.
inder
Post by inder »
polosilver you need the pic m8?
