sanders
Drives: 6r bluemotion tdi 1.2
Post by sanders »
Will do ciclo,
Could it be the lightswitch? Because when I push the knob to disengage the switch the green light from the foglight turnsters red as it should be. I check the wiring again hope to find something.
Verstuurd vanaf mijn GT-I9505 met Tapatalk
Then, in that case, post here the coding of your BCM & RLS, only.
sanders
Post by sanders »
i opened a new topic with the full vcds scan ciclo :mrgreen:
saw your post to late but if you like i could post it her also
sanders
Post by sanders »
scan from bcm with rls
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0353
Revision: BU050001 Serial number: 0456 026120185
Coding: 3AB02BBF08F32400B3380FB06EAB0ED95F80612F7E862441200000000000
Shop #: WSC 00788 648 00255
VCID: 418F3546D8FEA016D43-8014
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 270812 05 54 0403
Coding: 06302D
sanders wrote:scan from bcm with rls
http://www.uk-polos.net/viewtopic.php?f ... 18#p500522
sanders
Post by sanders »
what i did find ciclo, is that when i was removing the pin out of the 17 pin connector i didn't had a pin on position three (daylight).
but if i check the schematic on etka don't i need from pin 8 on 17 pin connector a wire thru pin 7 on bcm t73a? i saw on your schematic that it is only for retrofit?
greetz
sanders wrote:what i did find ciclo, is that when i was removing the pin out of the 17 pin connector i didn't had a pin on position three (daylight).
greetz
http://www.uk-polos.net/viewtopic.php?f ... 43#p500543
how come your AUX port has a little cover on it? :)
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
iichel wrote:how come your AUX port has a little cover on it? :)
Isn't that how they all are???
mine looks like this:
CNK
Drives: 6R
Post by CNK »
I also have a AUX port like iichel:
I think it's pretty clear ...
It is a business strategy that affects my brain. :lol:
Or also it's a simply a matter of chastity :) ... to prevent FOD. Foreign Object Damage.
But there is always a good solution for all ...
the new port is part number 6R0035724 and it looks like a straigt fit. should cost around 10 euros.
Yes, it uses the same connector as the old one (5M0035714).
"FOD" yes used a lot in aerospace industries, we have a guy that gets called FOD, but that stands for "F" off Dave, though stolen from the original use of FOD! As you might guess, he was not everyone's best friend!
Locked
