Cant bloody wait
The New Look
Just cleaned and sanded it all down, heated some plastic over the major holes and then used p38 to fill it
I used about 4 passes with filler, sanding and spraying after each pass, to get it to where it is now and its still not perfect, I need an orbital sander really but i couldnt be bothered to buy one
I should also have used a mix of fibre glass resin to give it some strength as it will crack if im not careful but its not that important here as when the bumper is fixed on it should be pretty sturdy.
To finish off i just we and dry sanded the whole lot, primered and sanded again ready for paint
Randall
Ok what sort of plastic did u use? where did u buy it from? guess it would be alrite to use a blow torch on or did u use another method
As for the fibre glass factor thats cool - i may give it a go sumtime...me first fibre glass project will be takin place over xmas making up some customer speaker pods on me bro mk2 golf
