Need help with amp
ModifiedMadness
- Sponsor
Bran
- Drives: VW Polo 1.2 TDI 2012
ok i finally got this sorted -
I got this guy to run a test on my wires and there was hardly any power going to my amp (should be 12watts, only was getting about 2) so he did a test from the battery to the main fuse (thats near the battery) and it was running at 12, so it had to be the main fuse.
it turned out to be the fuse thats near the battery, it was too high, it had a 60amp fuse, so i just put a lower fuse in and it worked
problem solved......
bass mekanik
wouldnt have anything to do with the rating if the rating was too high. More than likely that the fuse was acutally blown but you couldnt see it.Bran wrote:ok i finally got this sorted -
Bran
the fuse wasn't blown because my friends lower watt amp worked with itbass mekanik wrote:wouldnt have anything to do with the rating if the rating was too high. More than likely that the fuse was acutally blown but you couldnt see it.Bran wrote:ok i finally got this sorted -
ModifiedMadness
- Sponsor
