OH DEAR, i think ive hit my 1st major problem, help
polo boi
Post by polo boi »
oh an ive also 2 respray my rims :P
Weedle
Post by Weedle »
polo boi wrote:well ill not get in2 real technical stuff if until i sort the fuel out an if it dosnt change then ill do the throttle body, but im sure its the fuel bein dirty
yeah well just thought id suggest it as its easy enough to do !! just spray carb cleaner in it and mop it out with a rag !!
Good luck anywayz :o
polo boi
Post by polo boi »
ive heard quite alot of bad stuff about carb cleaner from the rest of the guys here, an how it messes otha things up etc,
Weedle
Post by Weedle »
or brake cleaner or something - im sure theres a diy guide on here !!
polo boi
Post by polo boi »
brake cleaner! in the throttle body!?
Weedle
Post by Weedle »
Ive had a long day - i cant be bothered searching for the thread and i cant remember so its the best i could come up with -
i have the memory of a goldfish !!! :roll:
polo boi
Post by polo boi »
also, how hard would it be 2 install lowering springs? if i had the compressors? i think i could do it on my own, i just dont have the confidence 2 try it? :oops:
polo boi
Post by polo boi »
yes, im inda mix! my girlfriends dad has all the tools, i had forgot thats where i usually work at on my car, lol, all i need is the coil spring compressors, he might have a set, if so, there bein fitted 2moz :P
warrmr
Post by warrmr »
its not technical. its as easy as sticking a can of redex in the fuel tank.
all you do is take the airbox off and spray some carb cleaner down the hole while pulling the accelerator cable. i cant remember if you do it with the engine on or off. but you will feel more improvement doing it that way than putting redex in the fuel system. or just change the fuel filter i dont rate fuel addatives.
if you want to "Clean" the Fuel drain the tank put the pterol in a clear container. wait 24-48 hours and you will see that the fuel and water have layered the water will be on the bottom and "clean" petrol on top skim the top layer off and jobs a goodun.
Ryan
Post by Ryan »
I get this problem, happend again today, seems to only do it when i drive around for acouple of hours turn engine off then try and start it but nowt, i usly just put my foot to the floor start it a few times then its fine again!
polo boi
Post by polo boi »
theres my springs, finally got a snap shot of them, ill try an get pics of my car 2nite, its basically standard, but sure u's will get 2 it at last
polo power
Post by polo power »
try fitting a new temp sensor chap, its on the side of the coolant expansion bottle
dragon_green
Post by dragon_green »
did you get the starting problem fixed?
polo boi
Post by polo boi »
it just sorted itself, i havnt had any problems, i didnt add any redex or anyting, it just started everytime
