+ APR Stage 2 +
- KennyPOLO_Gti
Its about increasing the breathing ability of the engine, its like putitng the PD intake and filter on, it wont give massive gains, but it will help the engine to breathe.
The turbo and DV return noise is louder now aswell as a result.
The difference in the car is more noticable than the PD intake, and with your rempa certainly wont hurt.
- KennyPOLO_Gti
Aye fitted it myself, bit awkward, but no too bad, there is an allen bolt you need to remove to get the factory inlet off the turbo, and i needed to slack the metal water pipe that runs around the head to get enough room.
Easier to jack the car up to get the bolt and clips from underneath as well as the top.
Heard mixed reports about the Split-R valve, some say it throws fault codes, some say it doesnt.
I wouldnt fit one as i hate the woosh from an atmospheric dump valve.
- KennyPOLO_Gti
kc
- Drives: an imaginary one... for now
i too have the inlet pipe fitted to mine and it improves it by loads! the power delivery i noticed that theres quicker response on the throttle and its definately louder!andy947 wrote:Get a Forge Turbo Inlet Pipe, fitted mine recently along with the Intercooler to throttle body hose and its a definate improvement, dont have any side by side pictures of the original and Forge part, but its a lot bigger!!!!
- KennyPOLO_Gti
i had been looking in to the same 2 hoses andy that are made by apr tuned, but the availability on them is scarse and at the minute is factory order, whereas the forge ones are just off the shelf, so may get the forge ones instead
is there much work involved on the fitting of them? would it take long to do by a professional, i.e awesome gti?
is the intercooler one a bumper off job and is the tip hard to get on?
ah right cool, sounds good that then
them 2 will be next then after i have paid off the brakes, cheers for the help andy
im also forced to stick to a side mount cooler as i have a winter pack with headlight washers, so a front mount would foul, so ill be looking to vent the drivers side arch someway to prevent a bit of heat soak, but im gonna attempt a different method to the people who have basically cut and shut the tt vent in place
