car washing in the snow, surely im not mad???
whitegtipolo
Re: car washing in the snow, surely im not mad???
Post by whitegtipolo »
nice!! i got my self a pressure washer the other day !!! lovin it!! :P
Jeff GTi
Post by Jeff GTi »
aaron, personally, i remove it with the aid of meguiars last touch detailing spray applied to a drying towel, but there is no right or wrong way to do it, i just find that doing it this way stops any ghosting occuring
trial and error and personal choice really, try both, and see which you prefer
white
pressure washers rock, now all you need is the snow foam lance from elite
Tim_GTi
Post Whore
Post by Tim_GTi »
Lubricant use is just to aid it off if you find it a little tricky. Esp. in the colder months.
Creedy
Post by Creedy »
Your cars lookin very nice Jeff... cant wait to see the wheels on it... even if for only a few months ;-)
So hard to kep the car clean in the winter, u wash it and within days its stinkin again.
When ever ive polished the car, ive clayed it, then used AG stuff to wax and seal, but dont find the finish to last that long atall.
How good is this Collinite 915 stuff and can you use it on any colour car? (as i know you cant with the dojo stuff etc) My car is the Olympic blue and want it with alot more wet look.
As first time maybe tryin this Collinite stuff, should i try the 915 or the 476, and any tips would be awesome..
Tim_GTi
Post Whore
Post by Tim_GTi »
I'd go with the 476s, it's great on darker coloured cars (mine's black), lasts ages and is a real breeze to use. 3
Check out this kit:
http://www.elitecarcare.co.uk/collinite ... ng-kit.php
It's got everything you need for applying. using the pad apply to the whole car, let it sit for 20 mins then buff off with a MF cloth. Or do it panel by panel, depending on your preference (although this process takes longer you've got to wait for it to cure properly!).
Apply some water or quick detailer before wiping off if you find the wax hard to buff off.
If your patient, try and get 2-3 coats of it on the car.
aaronon
Post by aaronon »
My collinite should be arriving soon :) I can't wait to get it on!!
Should I leave an hour between coats of wax? . . .or should I do the car . . .then repeat straight away.
I can't wait for it to look super shiney.
Jeff GTi
Post by Jeff GTi »
i did as you did tim, do full car then remove it
aaron, leave each coat 24 hours in between to allow it to cure properly
chrisjames
Post by chrisjames »
My neighbours would kill me for freezing the street, hats of though mate :P
Tim_GTi
Post Whore
Post by Tim_GTi »
chrisjames wrote:My neighbours would kill me for freezing the street, hats of though mate :P
I clean mine no matter what the weather also, if it needs done I do it. Problem is I've just burst a pipe in an attempt to get the outside tap going :(
aaronon
Post by aaronon »
I waxed mine this morning. The collinite looks amazing!
The only question I have is that while I was waxing the paintwork looks really brilliant. But when I looked down on the roof from my window above I noticed some streaking. You can't tell from down below as at eye level it looks brilliant. Should I just leave it and does that go away?
Thanks for the collinite recomendation.
Jeff GTi
Post by Jeff GTi »
i guess you took it off dry then?
taking it off with a damp drying towel first, them a final buff with a microfibre stops the ghosting effect mate
more-bhp
Post by more-bhp »
Attention Jeffgti.. mad winter cleaner....
On the subject of cleaning Jeff - what is the best thing to use to clean the Cabriolet's roof...
It has a touch of green on the rear which is quite stuborn to remove.....
Cheers J
Jeff GTi
Post by Jeff GTi »
try a safe degreaser and apc mix, leave it to soak and aggitate with a brush and pressure wash it off after 15 mins
more-bhp
Post by more-bhp »
Safe degreaser like ???? cheers J
