I don't know why one side raises either
Thanks for the reply
About the same as mine, think i'll put the old drop links on!chewy wrote:I would say between 60-70mm
Just the onechewy wrote:When you turn the wheel do both side lift or only one?
There is just the one adjuster 'ring' on each damper isn't there, the one that the spring is seated on? The spring is the correct way round, flat bit of spring on top of the adjuster.chewy wrote:Could be your spring in not sitting right or you have not tightened the adjuster ring up enough
