Oh man, That really sucks!alexperkins wrote:wiring diagram mate thats what it means
On further investigation into this, the electric window rollup is controlled by a trigger from the CL pump to the convenience system control unit, which is linked to the electric windows, and this tells them to go up.
It would be wise to remove the relay, and not use the rollup feature, as its not designed to work on this car im afraid. Just checked the rclick manual, and it definately wont work
Rclick Window Rollup installation
Re: Rclick Window Rollup installation
Oh that sucks!alexperkins wrote:wiring diagram mate thats what it means
But whoever wrote the instructions must of got it working right?
The instructions I believe are possibly for a 6n after checking the wiring colouring. Grey/red is a 6n CL pump lock wire. This is before they started using convenience modules to control everything.
Having said that - I have a friend with a 6n2 and a clifford alarm (I think) and his windows roll-up on lock
very strange it works on my polo when locked both windows roll up
I accidentally had it installed the wrong way (pin 85 & 30) when i touched the door lock wire onto pin 30 it locked and windows rolled up, as it should. But when I unlocked and tried it again it did not want to lock but the indicator lights flashed to say it had locked. I don't know if this helps.jacko7165 wrote:very strange it works on my polo when locked both windows roll up
Hmm thats odd. hopefully you havent shorted anything. Check for blown fuses. Its possible you fused the cl pump
I've checked all fuses and they are all goodalexperkins wrote:Hmm thats odd. hopefully you havent shorted anything. Check for blown fuses. Its possible you fused the cl pump
What does the 'bong' sound usually indicate?
