Secondary Speed Display - Sorted!
wobbler
Re: Secondary Speed Display - Sorted!
Post by wobbler »
http://www.ilexa.co.uk and http://www.gendan.co.uk are 2 UK suppliers.
To get the mph on the display just go into 17-instruments and go into long coding and change the region from UK to Australia. Don't feel tempted to pick one of the other options. All have issues like the US makes all mpg calculations in US gallons, and the Saudi setting gives a speed warning you cant disable at 74 mph or something similar.
As for the rear lights, it's in 09- central electrics. It's the option that relates to parking lights I can't remember off hand as my vag com laptop is at work, but I'll update tomorrow.
daydotz
Post by daydotz »
Is their anything about auto lights / coming home lights in vagcom ?
I know you would need a rain sensor an new switch
Edi30
Post by Edi30 »
daydotz wrote:Is their anything about auto lights / coming home lights in vagcom ?
The rain sensor fitted to mine does not have dusk sensor built in so would need a different part. Is there any way that vagcom could just be used to enable coming/leaving home lights when you lock and unlock the car without the dusk sensor?
Blaade
Post by Blaade »
Changed the region to Australia and all it did was change the miles to kilometres ??
whitegtipolo
Post by whitegtipolo »
Blade is yours a gti
smn88888
Post by smn88888 »
Edi30 wrote:
Tyler Owen wrote:That is quality need this done asap !
Wonder if i can sweet talk my dealer lol
Going to ask dealer if they will do this as they did auto door lock/unlock.
See the auto door unlock/lock. did it take much persuasion and what did it cost? I might try and get this done. :)
Edi30
Post by Edi30 »
I have known my dealer for over 16 years so just asked and was done FOC.
Blaade
Post by Blaade »
whitegtipolo wrote:Blade is yours a gti
Yes mate
Edi30
Post by Edi30 »
Edi30 wrote: The rain sensor fitted to mine does not have dusk sensor built in so would need a different part. Is there any way that vagcom could just be used to enable coming/leaving home lights when you lock and unlock the car without the dusk sensor?
Sorry I got this wrong the sensor built into the screen of my Polo looks identical to the sensor on my Golf which has auto lights :oops: Perhaps it's just a new switch and a reprogram to enable auto coming/leaving home lights? Can any one confirm if the dusk sensor is built into the rain sensor as I think it is?
daydotz
Post by daydotz »
where is the port socket can you take a pic of it ?
what version of vcds are you using is it cleary labeled as a far as i knew the polo 6r hasnt been added to software ?
Blaade
Post by Blaade »
You need a HEX-USB+CAN
Blaade
Post by Blaade »
Blaade wrote:Changed the region to Australia and all it did was change the miles to kilometres ??
Anyone explain why this doesn,t work for me?
daydotz
Post by daydotz »
I may have come up with Another idea if you still want auto lights seat do an accessory kit
daydotz
Post by daydotz »
i cant find even find Australia listed :? i think i was in the wrong menu
Guide
Go to 17-Instruments and look under Coding, then (IIRC) on the first page, there is a drop down list of countries (it will currently be set as UK) change it to Australia, this is all you need VCDS for.
Then on the car's maxidot go to:
MFD
SETTINGS
Units,
"Consu/distance" change this back to mpg (GB), mi (as it defaults to 1/100km, km),
then
SETTINGS
"MFD data" and make sure the box for Digit.speed is ticked
then
SETTINGS
and unticked the "ALT.speed dis." box (this will remove the KPH speed and replace it with the outside temp display)
[/size]
BlackSEL
Post by BlackSEL »
Has anyone solved this? can't find anything on the net.
