Few Snaps From Tonight
Re: Few Snaps From Tonight
thats alright tim, cheers liking your new polo btw
- Tim_GTi
- Post Whore
Thanks matematt_123 wrote:thats alright tim, cheers liking your new polo btw
Can you remove the inserts on the steering wheel then?
And what did you use to re-secure the pillars (assuming you have to take them off to put the tape on?)
Steering wheel inserts just pull off. For the pillars you have to remove the window lining running along the pillar and you will see 2 screws just undo them and it slides straight offTim_GTi wrote:Thanks matematt_123 wrote:thats alright tim, cheers liking your new polo btw![]()
yeah at Gtimatt said , B pillars just screw on with two screws so pull back the rubber lining and ull find the two screws up do them and itll slide off sideways, also put a cloth of something to stop the screws from going down into the door car bit as you may drop them I did but luckily put a cloth there
and the inserts just pull out, simples.
- Tim_GTi
- Post Whore
Thanks for the info guys!
