no problem, it would suck if you hear about this afterwards and you diddn't have a chance to concider youre plans anymore...
GT28RS is not bolt on as they have other flanges.
but Jabbasports makes manifolds that fit 1.8T engines and have a garret flange on it or even a IHI one.
with a GT28RS on full boost and engine in good condition etc you can let it make up to 360HP.
so when you let it run around 300-320 you will have no problems with the stock engine and youre turbo will run 100% safe
IHI VF24 is also a solution as they produce max 330-350Hp but they have a slightly faster spool up as the GT28RS.
but the GT28RS is slightly more brutal
depends on what you want.
hybrid with a good custom remap is verry good also.
the ibiza in the picture runs a frankenturbo K03s hybridcan make in and it makes about 250Hp.
but it's not on full boost because it's more built for the track.
on full boost 260-270 is do-able.
so a k04 Hybrid in good conditions can make it to 300HP but it will run on max capacity.
no big deal but depends on what you want to do with youre car.. not recommended for track use on full boost.
hope the link works, this is the manifolds you need in case of Garret/IHI
http://www.jabbasport.com/store/index.p ... ef=JSEM20V
