Thx for the links.aaronon wrote:Loom is here:
http://www.kufatec.co.uk/shop/en/Volksw ... VW-Polo-6R
Switch is £60-70 I think but apparently it's the EXACT same as ones from previous VW's and therefore is available on ebay here:
http://item.mobileweb.ebay.co.uk/viewit ... 5113524765
Still haven't decided whether to wire it up as apparently some BMC's aren't simple to hook the fogs up to. I think ill just do it for looks? I can't find the BMC number and still wouldn't be sure about installing them. I post fitted fogs in my 9N3 and noticed that my lights used to blow a lot more (and on the dash there'd be no front fog light showing up, only the rear so it always felt a bit unofficial)
I sent a message to that eBayer with the switch and he said that his switch would NOT work with the 6R. Not sure if he knows or just saying no to cover himself.
I too don't know if control module that I have will work with the fogs. Waiting or a vag cable to find out what I have.
Regarding the wiring loom, I just looked at Elsawin to see how to install the lights. It says that the front bumper needs to be removed in order to enable the removal of the blank fog light covers - strange.
Even stranger, the diagrams regarding the lights themselves talk about TWO bulbs in the fog lights - Daytime Running Light bulb and the actual fog light bulb. There was no mention of a fog light WITHOUT the DRL. Now the kufatec harness looks like it is does not include DRL connector.
See here:
Confused now
