Best Xenon style Halogen bulb.
chrispy.
Re: Best Xenon style Halogen bulb.
Post by chrispy. »
Thanks Aj!
Ill order some and post results
helloimjammie
Post by helloimjammie »
What AJ said.. my ultra power bulbs are brighter than standard and light up road signs brilliantly. . As was said not as bright as bulbs that are made to be brighter but brighther as they are 5000k white.. not 4000 odd k. :-)
Sent from my GT-N7000 using Tapatalk 4
andyc315
Post by andyc315 »
5000k refers to the temperature (colour) and is nothing to do with how bright they are
Sent from my GT-I9100P using Tapatalk 2
aaronon
Post by aaronon »
Gonna pick up these MTEC ones as I hate my yellow lights.
Is there are version of these bulbs that will fit the daylight/sidelight bulbs?
helloimjammie
Yah I know what it refers to? 5000k is the brightest on the scale as its pure white.. as soon as you hit 8000k-12000k its dim.. and I'm saying from what I've found through changing my lights that 5000k bulbs generally give out more light than a yellowy 4300k bulb..
aaronon
Post by aaronon »
God another question... Are these h7's the standard lights you use? Or the ones you only use in pitch black with no other cars around with the full beam.
Are the errors mentioned in this listing canbus errors? So you don't get any with the MTEC's?
Basically the OP and myself could buy these:
http://item.mobileweb.ebay.co.uk/viewit ... 1133009334
http://item.mobileweb.ebay.co.uk/viewit ... cmd=VIDESC
chrispy.
Post by chrispy. »
Ordered! Being delivered tomorrow, will update with pictures.
aaronon
Post by aaronon »
I ordered them too haha. Coming tomorrow. :)
Hopefully much easier to get in that the 9N3 where you needed someone with the smallest hand in the universe to get in the passenger side sidelight.
aaronon
Post by aaronon »
Ok pretty scared....
Read on a forum that the bulbs needed for the polo 6R are actually H4 and not H7 and have 3 prongs not 2.
On top of that it says you need to take off the actual headlight to access the dipped beam. What's up with that :(:(
chrispy.
Post by chrispy. »
Your theory is correct - you would ideally need to remove the headlight as the Passenger bulb is closed in by the battery
Plus you have to get your hand right inside to remove the holder for the bulb.
Secondly, my light sequence goes - DRL's - Side's - Dipped beam.
The DRL's and Dipped share the same bulb.
I believe I have the Twin Headlight system as it says so in my manual.
Does anyone know what bulb the Dipped beam is? H4 or H7 as AutoBulbsDirect said my dipped beam is a H7, and full beam is H1, when actually the full beam is a H7.
Thirdly. MTEC's ROCK! So much better than the candles VW supply you with :) and only £12
aaronon
Post by aaronon »
Are the lights easy to get back on or will I need to go to a garage to get them realigned?
I think I found out how to tell whether you're h4 or h7!!! If your lamp has two bulbs close together in the bit of lamp closest to the grille then you're h7..... If you've just one then you're h4!
Can anyone who is taking their headlights out to change a bulb please do a wee guide with photos? The manual isn't clear and I have the bulbs but know ill balls up taking the headlight out and end up breaking it :(
chrispy.
Post by chrispy. »
I managed to do it without removing the headlights. Very difficult but i managed it.
I have a large dipped beam bulb on the outer side of the headlight, which has a grille cover over the bulb, then on the innerside i have the full beam with side light inside that circle, then below i have the indicater.
I will give VW a ring later today and find out more.
chrispy.
Post by chrispy. »
So I've done some digging around and found some information -
2009+ Polo's (it may be installed on previous models, can't confirm) come with a Single or Twin headlight system.
The Single headlight system have Dipped & Main sharing the same bulb, which is a H4.
The Twin headlight system use 2 H7's as one bulb is Dipped beam & DRL's, & the other takes care of the main beam.
VW was no use what so ever, the guy from the parts department had no clue what I was talking about. Ironic.
Auto Bulbs Direct was also wrong.
I will be getting a second set of H7's and will post pictures soon with a step by step.
Hope this helps or has cleared any confusion.
hornmeister
Post by hornmeister »
I for one would definitly appreciate this. There seems to be no info anywhere online, other than foglights.
Cheers in advance for your efforts.
chrispy.
Post by chrispy. »
Just fitted the bulbs. They are very easy once you get the hang of it.
Will need a spare pair of hands FYI.
Ordered more H7's for main beam & LED side lights.
Will take pictures and post up a step by step by the weekend.
