autolights
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Re: autolights
Post by Mart!n-GTI-DK »
gtblue wrote:Thanks for all the Info.
When I buy Kufatec kit, I have to choose "Factory fitted fog lights?:"
I don't have Factory fog but maybe I will get them in the next months.
What do you think I should choose and what are the differences in the kit if I choose that.
Thanks.
I have fittet foglights to my BlueGT aswell. Couldn't have them from the factory because of th Bi-Xenon's.
But they work fine and you also need the switch for the foglights aswell. :)
Only thing is that you can't code it to us the foglights for the Coming/leaving home since they go around the BCM.
joelburbidge wrote:Can some confirm this the foglights for the bluegt are the same as the gti and the gti foglights part number is 6r0 941 062f
The foglights are the same... BUT as with the GTI you need the ones without DRL if you have Bi-Xenons.
You have only listed the number for one of the lights. The part numbers are:
6R0 941 061 F - Left foglight without DRL
6R0 941 062 F - Right foglight without DRL
Re: autolights
Info:
For the CH / LH can be encoded as follows: (My BCM)
joelburbidge
Re: autolights
Post by joelburbidge »
I just listed one for quickness that's the number that I have given to parts department and I've end up with the standard ones so annoyed
Mart!n-GTI-DK
Re: autolights
ciclo wrote:Info:
Not if the foglights aren't factory fittet... Because they aren't connected to the BCM.
But did you have to change the number for the highbeams to work after installing?
gtblue
Re: autolights
Post by gtblue »
Mart!n-GTI-DK wrote:
ciclo wrote:Info:
It's seems to use the lowbean instead of the foglight for CH/LH. I think I will prefer that if I have bixenons.
Re: autolights
Clearly Mart!n. I put the information because gtblue asked kufatect kit had to choose and to show that without fog lamps can set the CH/LH. (with xenon)
I do not remember if I changed the number or factory was well configured.
gtblue
Re: autolights
Post by gtblue »
ciclo wrote:Clearly Mart!n. I put the information because gtblue asked kufatect kit had to choose and to show that without fog lamps can set the CH/LH. (with xenon)
Thanks.
I finnaly want to install foglights and autolight, so if I'not wrong I have to order the kufatec autolight wire for cars with foglights and also the kufatec wire for foglights retrofit, havn't I?
Re: autolights
WD fog lights without DRL, ADL, CH/LH
WDs fog lights with:
Image Image
gtblue
Re: autolights
Post by gtblue »
ciclo wrote:I think it's better that you choose the kit without factory fog lights because the CH/LH can have it through the xenon headlights (low beam).
After the installation of the fog lights is simpler. (I think I posted in the forum electric diagram).
To install the fog lights as factory to have the CH/LH, ADL, and other parameters, is necessary to have a high BCM. Your BCM is surely high, but as I mention it's easier to install the fog lights without these features.
As you see, I have configured the CH / LH xenon headlights and is much better than through the fog lamps. White and clear ... My factory fog lights are not connected to the BCM.
Image Image
Thanks for the reply.
If I order the kit without Factory fog's, does the light switch will come with the front fog position?
Maybe all the light switch that have the auto position also have the front fog position; but I don't want to have a light switch with auto and without front fog position that I need for the future non factory front fogs.
Thanks, Gracies,
Re: autolights
It matters little take the light switch with front fog position and not have the front fog lamps (considering that you're going to install in the future). I've never seen a light switch to AUTO position without front fog position. I do not know if it exists. :?
Best Regards .. :D
edit.... :lol:
http://www.bold-sport.com/store/index.p ... uct_id=203
joelburbidge
Re: autolights
how do you gain access to the bcm struggling to figure out how im meant to put the wires into it
Mart!n-GTI-DK
Re: autolights
joelburbidge wrote:how do you gain access to the bcm struggling to figure out how im meant to put the wires into it
take out the seat and lay on your back looking up... It's a pain in the ass but take your time and make sure to do it right the first time...
Re: autolights
Re: autolights
For anyone interested, I ordered a second one of the mk4 golf auto headlight modules and switches for my 6R and it works perfectly
Just had to tape over the TfL pin so only sidelights run as DRLs
Works just the same as on my 6N2 now :)
Re: autolights
Do you have an image or link of the auto headlights module?
I misread and thought you installed xenon headlights.
