All6R.Emergency Brake Flashing (Brake light) active.(TESTED)
Re: All6R.Emergency Brake Flashing (Brake light) active.(TESTED)
Hello fellow ,i am with the translator i am sorry for not to speak or write English ,but i have problems with the activation of the flashing lights of emergency and brakes ,and wiring the bcm and activated the bit .and i am not work .done all accurate as e read ,i ask help to be able to make that work many thankshello my bcm cycle is high -end is a ibiza .... have enabled several modifications .mirando elsa see you have abs module wiring to the bcm J623 cable .After .com possible switch to cable me miss the module bcm abs? .......
Hi AVENOX, welcome.
Have you checked the reference number of your BCM? Please tell me what is the reference number.
hello cicle is a Ibiza and active cornering lights and preguta .my something more is whether to wire the ABS module to the bcm otherwise carries the wiring 42
Hola AVENOX, tienes un mensaje privado, comprueba tu bandeja de entrada (inbox).AVENOX wrote:hello cicle is a Ibiza and active cornering lights and preguta .my something more is whether to wire the ABS module to the bcm otherwise carries the wiring 42
tell a compatible reference thanks or where I can find the reference....
this is a better option ...... 7h0937088c or 7h93090A
sorry that you got is what brought the car .the I carry is 6R0937087B
