UK-POLOS.NET - THE VW Polo Forum • Newbie, maunual clutch cable conversion-Arosa - Page 2
Page 2 of 3
Re: Newbie, maunual clutch cable conversion-Arosa
Posted: Thu Oct 15, 2015 9:28 pm
by piglet14
3l,,,wow, the 106 is 2l
I don't think I've got a 17mm hex either.
Does it need to be drained?
Does oil pour out of the drive shaft holes?
Posted: Thu Oct 15, 2015 9:29 pm
by alexperkins
Drained through the drain plug fill throughout the fill plug
Posted: Thu Oct 15, 2015 9:54 pm
by piglet14
What happens if you don't drain it? does it end up all over the floor?
Posted: Thu Oct 15, 2015 10:00 pm
by alexperkins
For changing the clutch you don't have to drain it at all
That can be done with the gearbox full
Posted: Sat Oct 17, 2015 12:34 pm
by piglet14
Is this the correct spline bit? M8?
http://www.ebay.co.uk/itm/281324520461
or
http://www.ebay.co.uk/itm/321179925405
long or short?
Posted: Sat Oct 17, 2015 12:35 pm
by alexperkins
Long. It's an utter PITA otherwise
Posted: Sat Oct 17, 2015 12:38 pm
by piglet14
That's what I thought.
Is there a gasket behind the D/S flange that needs renewing?
Posted: Sat Oct 17, 2015 1:37 pm
by alexperkins
Not unless it's leaking
Posted: Mon Oct 26, 2015 9:38 am
by piglet14
Gearbox out, not too hard.
Stuck with release slide screws, what size spline drive?
Posted: Mon Oct 26, 2015 9:40 am
by alexperkins
Release slide screws? Can you be more specific
Posted: Mon Oct 26, 2015 9:47 am
by piglet14
3 screws holding release bearing slide/sleeve/tube.
Spline drive smaller than the M8 on the Inner CV's
Posted: Mon Oct 26, 2015 10:04 am
by alexperkins
Oh those, I think its M6, though it might be M7 according to the listing
Posted: Mon Oct 26, 2015 11:06 am
by piglet14
Just phoned my local factors, none of his sets include M7 so hope it's M6
Also, how do extract the selector shaft seal? Dig it out with screwdrivers?
Posted: Mon Oct 26, 2015 11:13 am
by alexperkins
You can use an allen head failing it not being an M6..its been a while since ive changed one of those
Yes, or with like a dentist pick
Youll need to be careful removing it as you dont want to scratch the housing or the shaft
Refitting your best to use a deep socket over the selector shaft and tap the end with a mallet to seat it nicely.
Posted: Mon Oct 26, 2015 11:17 am
by piglet14
I tried an Allen on one last night, it slipped. Pretty sure that was a 6mm if that means anything.
I've got a decent size braddle point I could lever over something, how tight are they?
