Benji58 - Polo 6R TDI 75 - R-Line Conversion
- CNK
- Drives: 6R
Re: Benji58 - Polo 6R TDI 75 - R-Line Conversion
Very nice Polo!
Really tasteful OEM mods. I think the Golf ED35 Watkins Glen style wheels really suit the Polo.
Awesome ... I'm speechless, trying to be less emotional and more rational.benji58 wrote:Hello everybody !
(...have been some years since we met in the French forum...)
Excellent JOB! Step by step. (effort, will, the money, time, etc...)
Your 6R R-line it's awesome.
Maybe you'll never forget this car.
Norbreck21a
I think you are the first person I've ever seen that's done a manual to automatic climate control conversion. That must have been a nightmare with all the sensors and vent motors etc ? Was it a dash out job ?
Cool car by the way - very tasteful.
- CNK
- Drives: 6R
You forgot about @iichelNorbreck21a wrote:I think you are the first person I've ever seen that's done a manual to automatic climate control conversion. That must have been a nightmare with all the sensors and vent motors etc ? Was it a dash out job ?
CNK wrote:Very nice Polo!
Thank you !SRGTD wrote:Really tasteful OEM mods. I think the Golf ED35 Watkins Glen style wheels really suit the Polo.
Thanks a lot ciclo!ciclo wrote:Awesome ... I'm speechless, trying to be less emotional and more rational.
Your 6R R-line it's awesome.Enjoy it!
It's on I will never forget this car, after all this time passing on, to him added options, again and again ...
Yes CNK reason iichel did it also !Norbreck21a wrote:I think you are the first person I've ever seen that's done a manual to automatic climate control conversion. That must have been a nightmare with all the sensors and vent motors etc ? Was it a dash out job ?
Conversion is mostly patient and meticulous. It took me 3 working days (disassembling the entire dashboard and the heating block, modified wiring ...)
But now I am very happy everything works perfectly and I have no VCDS error
dash out... cross member out... not an easy job for sure
News for my polo
-Install folding mirrors OEM
-Upgrade BCM to 7E0937090B
And installation RDKS
work in progress
Ciclo helps me a lot right now to make this work
Ash6R
- Drives: Polo 1.2 TSI SEL
How much did it cost to get the R line body kit?
Car looks awesome btw
I'm working on it (very interestingbenji58 wrote:And installation RDKSwork in progress
Thanks !Ash6R wrote:How much did it cost to get the R line body kit?
For the price I will not tell you exactly, I no longer count
Thank you for your precious help, it is not simple for me this modciclo wrote:I'm working on it (very interesting).
Hello everyone
I'm asking for your help. To all the professionals of the polo 6R
I installed RDKS, but this one does not work .. (I can not find any solution)
My problems :
- No display on the cluster
- RDKS module does not recognize valves
My installation:
- RDKS Module 3AA907273F
- Valves RDK 5Q0907275B
- + 12V on terminal 30
- Can Lines on the powertrain
I tried to connect the CAN line on the IC, still no display on the cluster and an error communication in the gateway...
Where can my problem come from? Coding? RDKS module not compatible / failing? Incompatible cluster software? ....
My autoscan:
thank you in advance
My problems :
My installation:
My autoscan:
Type chassis: 6R (7E0)
Scanner: 01 03 08 09 10 15 17 19 25 37 44 47 55 56 65 0B
VIN: WVWZZZxxxxxxxxxxx Kilometrage: xxxxkm
01-Moteur -- Etat: OK 0000
03-Freins ABS -- Etat: OK 0000
08-Climatronic -- Etat: OK 0000
09-Centrale Elec. -- Etat: OK 0000
10-Assistance stationnt -- Etat: OK 0000
15-Airbags -- Etat: OK 0000
17-Instruments -- Etat: Défaut 0010
19-Gateway CAN -- Etat: OK 0000
25-Anti-démarrage -- Etat: OK 0000
37-Navigation -- Etat: OK 0000
44-Direction assistée -- Etat: OK 0000
47-Sonorisation -- Etat: OK 0000
55-Portée des feux -- Etat: Défaut 0010
56-Radio -- Etat: OK 0000
65-Pression pneus -- Etat: Défaut 0010
Adresse 01: Moteur (J0000-CFWA) Labels: 03P-906-021-CFW.clb
No. pièce Log: 03P 906 021 Mat: 03P 907 425 A
Pièce: R3 1.2 DCM3.7 H08 9505
Révision: 11003001 No. de série:
Codage: 00114014002400080000
No. Atelier: WSC 00000 000 00000
Jeu de données ASAM: EV_ECM12TDI03103P906021 001016
ROD: EV_ECM12TDI03103P906021.rod
VCID: 65C03E9B64A7E3697A-8030
Aucun code défaut trouvé.
Tests passés: 0000 0000
Adresse 03: Freins ABS (J104) Labels: 6R0-907-37x-ABS82.clb
No. pièce Log: 6R0 907 379 AE Mat: 6R0 907 379 AC
Pièce: ABS8.2 front H04 0001
Révision: --------
Codage: 200224E3016F00BB042824E980D700000000
No. Atelier: WSC 00788 648 00255
VCID: 01080A0B9CCF2F49E6-8054
Adresse 08: Climatronic (J255) Labels: 6R0-907-044.clb
No. pièce Log: 6R0 907 044 H Mat: 6R0 907 044 H
Pièce: Climatronic H11 0812
Révision: V0000000
VCID: 387EA7EF8B95AE8111-806C
Adresse 09: Centrale Elec. (J519) Labels: 7E0-937-BCM-V1.clb
No. pièce Log: 7E0 937 090 B Mat: 7E0 937 090
Pièce: BCM PQ25 Max4 H81 0744
Révision: B9081001 No. de série: 0982 259160361
Codage: 3CB029BF48E1240093280E917CEB97D05A80672F608D30C1200000030000
No. Atelier: WSC 02737 790 12345
VCID: 2A5A8DA745390C1197-807E
Sous-système 1 - No. pièce: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Pièce: RLS 161014 05 54 0403
Codage: 06302D
Sous-système 2 - No. pièce Log: 6R0 959 801 CE Mat: 6R0 959 801 CE Labels: 6R0-959-801.CLB
Pièce: J386__TSG_FT 003 9612
No. de série: KU0KU005051551253047
Codage: 0200A3
Sous-système 3 - No. pièce Log: 6R0 959 802 CJ Mat: 6R0 959 802 CJ Labels: 6R0-959-802.CLB
Pièce: J387__TSG_BT 003 9612
No. de série: KU0KU005051551250425
Codage: 1000AB
Sous-système 4 - No. pièce: 1K8 951 171 A
Pièce: DWA-Sensor 00 001 0103
Codage: 000000
Sous-système 5 - No. pièce: 1K0 951 605 C
Pièce: LIN BACKUP HO H05 1501
Codage: 000000
Sous-système 6 - No. pièce: 1K8 951 171 A
Codage: 000000
Sous-système 7 - No. pièce Log: 5K0 959 542 B Mat: 5K0 959 542 B
Pièce: E221__MFL-TAS H30 0036
No. de série: 0113742
Codage: 820000
Adresse 10: Assistance stationnt (J446) Labels: 7E0-919-475.clb
No. pièce Log: 7E0 919 475 J Mat: 7N0 919 475
Pièce: PARKHILFE 8K H06 0105
Révision: -------- No. de série: 28261224902578
Codage: 308001
No. Atelier: WSC 02756 790 50316
Jeu de données ASAM: EV_VW75XParkAssis8K 001003
ROD: EV_EPHVA18VW250GPCS.rod
VCID: 3978A2EBB89FB789EE-806C
Adresse 15: Airbags (J234) Labels: 5K0-959-655.clb
No. pièce Log: 6R0 959 655 K Mat: 6R0 959 655 K
Pièce: VW10Airbag01K H09 0020
Révision: -------- No. de série: 003GX00XLZLX
Codage: 00314B
Jeu de données ASAM: EV_AirbaVW10BPAVW250 A01001
VCID: 4A9AED27ED792C1177-801E
Capteur de collision du sac gonflable latéral: côté conducteur:
No. de série: 3575HRB405T0U20SAHVG
Capteur de collision de sac gonflable latéral: côté passager:
No. de série: 3585HRB405T0U20S2OJ4
Capteur de collision du sac gonflable latéral AR: côté cond.:
No. de série: 3515RRB405V0R8ACI0O3
Capteur de collision du sac gonflable latéral AR: côté pass.:
No. de série: 3525RRB40630Q8K49PJW
Adresse 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
No. pièce Log: 6R0 920 870 B Mat: 6R0 920 870 B
Pièce: KOMBI H05 0607
No. de série: 00000000000000
Codage: 140E01
No. Atelier: WSC 12345 123 12345
Jeu de données ASAM: EV_Kombi_UDS_VDD_RM09 A04716
VCID: 346693DF9FFD4AE13D-8060
1 Code défaut trouvé:
12658432 - Fonctionnement limité en raison de l'absence de message
U1111 00 [008] - -
Intermittent - Confirmé - Testé depuis RàZ mémoire
Capture:
Etat du défaut: 00000001
Priorité du défaut: 6
Fréquence du défaut: 1
Compteur de RAZ: 80
Kilometrage: xxxx km
Date: 2017.05.08
Temps: 19:16:39
Adresse 19: Gateway CAN (J533) Labels: Aucun
No. pièce Log: 7E0 909 901 Mat: 7E0 937 090
Pièce: GW-K-CAN TP20 H81 0744
Révision: B9081001
Codage: 002000
VCID: 68DE37AF9BB5FE0141-803C
Adresse 25: Anti-démarrage (J334) Labels: 5K0-920-xxx-25.clb
No. pièce Log: 5K0 953 234 Mat: 5K0 953 234
Pièce: IMMO H05 0607
Codage: 000000
Jeu de données ASAM: EV_Immo_UDS_VDD_RM09 A03709
VCID: 6ADA4DA78DB9CC1157-803E
Adresse 37: Navigation (J0506) Labels: 1T0-035-680.clb
No. pièce Log: 1T0 035 680 P Mat: 1T0 035 680 P
Pièce: RNS-MID H10 5270
Révision: AB001001 No. de série: VWZ6Z7N6370477
Codage: 04070040000000810001
VCID: 3B74B8E3BAA38599FC-806E
Sous-système 1 - No. pièce: 1T0 919 859 B
Pièce: EU West V14 8477
Adresse 44: Direction assistée Labels: 6Q0-423-156.clb
No. pièce: 6R0 423 156 B
Pièce: LenkhilfeTRW V277
Codage: 10130
VCID: 2F6C9CB3EADB693940-807A
Adresse 47: Sonorisation (R12) Labels: 5K0-035-456.clb
No. pièce Log: 5K0 035 456 Mat: 5K0 035 456
Pièce: KonzernAmp 8K 0340
Révision: -------- No. de série: BP218109097291
Jeu de données ASAM: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: 67DC34939EABF17948-8032
Adresse 55: Portée des feux (J431) Labels: 6R0-907-357.clb
No. pièce Log: 6R0 907 357 Mat: 6R0 907 357
Pièce: LWR-ECU H02 0070
Révision: -------- No. de série: --------------
Codage: 0112000001000000
Jeu de données ASAM: EV_HeadlRegulVWLWRPt 001004
VCID: 77FC64D3CE0B61F9D8-8022
13705474 - Bus de données
U1121 00 [137] - message manquant
Témoin allumé - Confirmé - Testé depuis RàZ mémoire
Capture:
Compteur de RAZ: 39
Date: 2017.05.08
Temps: 00:04:41
Adresse 56: Radio (J0506) Labels: 1T0-035-680.clb
Adresse 65: Pression pneus (J502) Labels: 3AA-907-273.clb
No. pièce Log: 3AA 907 273 F Mat: 5Q0 907 273
Pièce: RDKBERU30 H04 0011
No. de série: 40000000043140
Jeu de données ASAM: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_VW51.rod
VCID: 377CA4D38E8BA1F918-8062
8398082 - Capteur(s) de pression de pneus
C111A 31 [009] - Aucun signal
Capture:
Priorité du défaut: 3
Compteur de RAZ: 40
Date: 2017.05.08
Temps: 19:10:53
Vitesse du véhicule: 32 km/h
Température extérieure: 12.5 °C
Niveau de réception antenne 1: 540 mV
Niveau offset antenne 1: 270 mV
- 6RPotentialBuyer
- Drives: Candy White Polo 6R
Really nice mods dude! How are you sourcing all of these parts though?? I've been searching for ages for an R line conversion and the gloss black interior trim but they just don't come up for sale
Where do you buy your parts from??
The problem lies in the RDKS unit, does not receive signals from the sensors/valves, or sends signals to the IC.benji58 wrote: Where can my problem come from? Coding? RDKS module not compatible / failing? Incompatible cluster software? ....
Try to configure the adaptation channels again with VCDS.
Try also with the file that I sent you for VCP.
Maybe firegrafik or rdasadia can enlighten us about it.
Btw, you should install this sensor for your Bixenon headlights - Static Cornering Lights.
viewtopic.php?f=56&t=69603&start=15#p520005
Read the installation guide on that topic.
Read this topic http://www.mytiguan.com/index.php?/topi ... e-monitor/
Also this link for references http://forums.ross-tech.com/showthread. ... PMS-DIRECT
