HELP NEEDED!! Rear fog light retrofit Polo GTI 6R
Re: HELP NEEDED!! Rear fog light retrofit Polo GTI 6R
The Byte-Bits for Reverse (Back-Up light) and your new 'Rear fog light' are correct, they do not need to be modified.
However, New BCM coding*: (copy and paste from here)
35B029BF08E324009A280D916C6B9DD15A40472F600D10D0200000030000
Take a look at this guide (20 point) just to learn how to copy the new BCM coding from here and paste it.
*Activated functions in this new BCM coding
- Coming Home.
This function is possible because it is semiautomatic and does not require the light sensor.
How does it work :arrow: Stop the engine, pull once from stalk High Beam, the lights come on when you open the door.
- And the following functions.
viewtopic.php?f=56&t=58703&start=195#p477710
viewtopic.php?f=56&t=58703&start=765#p491539
viewtopic.php?f=56&t=58703&start=765#p491577
Once you enter the new coding, Autoscan ---> Gateway installation list ---> Clear all DTC's ---> Done .... wait for the new reading of Gateway installation list ---> click Start (new Autoscan) ---> Save it ---> Post here.
Check all lights and new features.
Automatic lights and Leaving Home require the light sensor. Leaving Home function is automatic.
You need to install the light sensor, but this is the kit that is installed by everyone (around the world) on their Polo 6R.
- Dimming mirror
- Rain Light Sensor
- Wiring
- And switch with AUTO function
Useful link
Once this kit is installed, you can install my wiring for automatic lights. Here the sale :arrow: YOU (BCM Max) need the A model.
With all this information you have saved an infinite amount of time and money. But let's continue...
You do not have cruise control, hmm... a GTI without CCS? OMG ... buy these stalks 'in this store'
It will be necessary to change the ring (for models without ESP) by your current one (for models with ESP,...very easy to do). The ring of the sale is not valid for your GTI, but this is the cheapest way to get CCS for your GTI. It will also be necessary to make a slight modification to the wiring of the sale, but I will send you the necessary when you buy my wiring of automatic lights.
Robingti
Drives: Gti 6r
Post by Robingti »
My DRL went off but the CH is active now
Chassis Type: 6R (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 2E 44 55 56 77 0B
VIN: WVWEP76R7EY153726 Mileage: 65210km-40519miles
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CTHE) Labels: 03C-907-309-V1.clb
Part No SW: 03C 906 026 K HW: 03C 907 309 N
Component: 1.4l R4 TSI H02 6414
Revision: LNH02--- Serial number:
Coding: 00250012000400000000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM14TSI01103C906026K 001006
ROD: GV_ECM14TSI011PQ25.rod
VCID: 285F92C653323102C8-807C
Readiness: 1110 0101
Part No SW: 0AM 300 061 M HW: 0AM 927 769 D
Component: GSG DSG AG7 431 5110
Revision: 00043014 Serial number: CU501310258091
Coding: 0000020
VCID: 35614BB25F805CEA43-5122
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0003
Serial number: --------------
Coding: 21DD6885432802C3841B166BC257404D0905
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: EV_Brake1ESP90iBOSCH_VW25.rod
VCID: 0F2DD95AD69C463A29-805A
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Serial number: 26111304650369
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF3949EE1365FB2D2-802A
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 39794782B098B88AA7-806C
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 0571 319132230
Coding: 35B029BF08E324009A280D916C6B9DD15A40472F600D10D0200000030000
VCID: 2D5163D274D0142A3B-8078
Subsystem 1 - Part No SW: 6R0 959 801 AT HW: 6R0 959 801 AT Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8620
Serial number: KU0KU008111300012728
Coding: 0000A0
Subsystem 2 - Part No SW: 6R0 959 802 BE HW: 6R0 959 802 BE Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8620
Serial number: KU0KU005111300011766
Coding: 1000A0
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
Component: J245 PS72.023 H02 0007
Serial number: WOO2517342+
Coding: 081001
Subsystem 7 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B
Component: E221__MFL-TAS H30 0036
Serial number: 0121672
Coding: 830000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 M HW: 6R0 959 655 M
Component: VW10Airbag030 H10 0020
Revision: -------- Serial number: 003GZ001K0E3
Coding: 003330
VCID: 4C970E56E70A3D220C-8018
Serial number: 3575HRB400Q50LNG5HH.
Serial number: 3585HRB400O50LNG58T$
Serial number: 3515RRB400U50PGE79U4
Serial number: 3525RRB401250PGEDOFR
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 D HW: 6R0 920 870 D
Component: KOMBI H04 0709
Coding: 140C01
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 36634CBE898657F24A-8062
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0712
Revision: B9074001
Coding: 002000
VCID: 70EFBAA6A36239C250-8024
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H04 0709
Serial number:
VCID: 6ADBA8CE8DBEC3121E-803E
Address 2E: Media Player 3
Cannot be reached
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11241
Shop #: WSC 00788
VCID: 306F7AA6F7E279C210-8064
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0110000001000000
VCID: 77FD81BACE0C6EFA91-8022
1 Fault Found:
5275648 - Left/Right Driving Switch-Over Active
C1080 00 [009] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 65216 km
Date: 2017.01.15
Time: 23:11:56
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0236
Revision: 00000001 Serial number: VWZ1Z3N3671732
Coding: 01000410020001
VCID: 244786F6271AD562E4-8070
Address 77: Telephone (J412) Labels: 5N0-035-729.clb
Part No SW: 5N0 035 729 B HW: 5N0 035 729 B
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007665390187
Coding: 0D00000080000010
Shop #: WSC 14160 993 999999
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 2F6D79DA76DC663A09-807A
End-------------------------(Elapsed Time: 03:47)--------------------------
DRL off? With handbrake Up... ONLY! :) (it's a new feature)
If you do not want this new feature enter this new BCM coding.
35B029BF08E324009A280D916C6B9DD15A40472F600D10C0200000030000
By the way, deactivate the 'Travel Mode' function in the 'Lights and Vision' menu of MFA+ (instrument cluster) to clear this fault:
1 Fault Found:
and again, Autoscan, gateway installation list, wait, Clear all DTC's, etc... and New Autoscan (if you want).
Robingti
Drives: Gti 6r
Post by Robingti »
I made a double check about the handbrake, it was on, that's why DRL went off :lol: lol
So if I understand correctly I dont need to 'activate' the rear fog light by turning on a bit, right? Just do the wiring? I was going to do it this weekend but I wasn't able :(
If so I will let you know the results. :)
The new message works great, the handbrake mode works, the DRL off while turning light on works and the CH function works terrific!!
Thanks a lot Cyclo :D
Yes. :wink:
Robingti
Drives: Gti 6r
Post by Robingti »
ciclo wrote:Yes. :wink:
By the way I can't see the diagrams of the 'right way' to do the wiring anymore. Could you please share them again? :mrgreen:
I love the new functions of the lights and DRL you sent me :D
Regards
Did not you download them?
I'm really sorry, I had to delete them because I need space in my google account to publish other diagrams or information ... (it is saturated with information)
I hope you remember how it was because I will not do it again. My time is very limited!!! ... I apologize for it, but I have to attend to many other people.
Opportunity and TRUST, those terms to take into consideration.
Robingti
Drives: Gti 6r
Post by Robingti »
Hello guys sorry for my late reply, I have been quite busy lately.
I have done all the connections as Ciclo said and IT WORKS!! :D:D:D :lol:
however at first step the "new rear fog light bulb" was white I replaced it with a red led bulb and now it looks like this:
I found out that the connection to the cluster was already there so when I turn on the rear fog a light in dash turns on too
I have seen that some switches turn on in yellow the rear fog light icon even though mine doesn't
Thanks Ciclo for all your help and sorry about asking twice for the diagrams I will keep in mind what you said. Now my next mod will be the auto lights set up.
Good job!. Thank you for the report! The need aroused your senses. :lol:
Have you visually checked that the wire for warning light of rear fog light is present in the instrument cluster connector (T32/13)? :)
Robingti
Drives: Gti 6r
Post by Robingti »
ciclo wrote:Good job!. Thank you for the report! The need aroused your senses. :lol:
No I have not. How can I be sure? I tried but I wasn't able to see the connector from the back of the dash.
Regards
you'll have to remove the cluster and remove the blue housing from the white terminal holder ;)
