Footwell light polo AW 2018
alanlaos
Drives: Polo GTS
Re: Footwell light polo AW 2018
Post by alanlaos »
grpipolo wrote: Wed Jun 17, 2020 4:43 am Hi,
My name is Gabriel and I’m from Brazil.
I’m also trying to retrofit the footwell lights on my 𝐏𝐨𝐥𝐨 aw.
I installed them and did the coding with vcds. Everything is working, except that the option to reduce/increase the brightness is not showing on my screen...
do you have any ideia what’s happening?
Thank you!
Hi grpipolo, I have a GTS also. I wire all like in this post and coding also but no idea why is not working.
I have in the infortainment the bar to set the % of the power light.
Any ideas?
Andy Beats
Post by Andy Beats »
Out of interest, has anyone changed the colour of the LED bulbs in the ambient lighting?
Something other than white would be nice, my 2009 Mini allowed a choice of colours.
Should be do-able in the door handles, middle cubby hole and footwells?
Obviously the strips along the dash and door would be more difficult, I'm happy to leave those white.
luizphill
Drives: Virtus Confortline 1.0 TSI
Post by luizphill »
Thank you!
Olá! Tu conseguiu resolver isto?
Qual o pino do chicote que instalou o positivo da footwell ?
Valeu
phnahes
Drives: AW
Post by phnahes »
luizphill wrote: Tue Oct 20, 2020 4:11 pm
Thank you!
Valeu
You must use the PIN 64 of Connector "C" from BCM, as image in the previous posts.
and use the code configuration above, about Leuchte32AMBL 2C64
