HID Headlight conversion
zainf7
Drives: Mk5 6R BlueGT
Re: HID Headlight conversion
Post by zainf7 »
I’ll try them.
Thanks for the help. :D
patil
Post by patil »
Hi again Zainf7
Please arrange for VCDS preferably, and get an autoscan and post here.
We need your BCM long coding, so that it can be edited to work with your aftermarket bixenons.
Your BCM should know that bixenons have been installed, so that it provides adequate power supply to your bixenons.It is currently coded for halogens. If coded correctly flickering should stop.
I had a similar situation like you with my aftermarket bixenons I had installed previously, with the help of Master ciclo and many thanks to him I learnt that BCM coding has to be changed for BCM Max( Not for BCM high/low.. these aftermarket bixenons work fine with low BCM's).
The errors might hang after coding change but bixenons should work fine. :)
zainf7
Post by zainf7 »
Hi all,
Got it sorted, went to one garage who tried to charge for new HID bulbs and ballasts with fitting then went to another who coded the BCM.
All fixed and working now. :D
Thanks for all the responses.
