Imitation is the most sincere form of flattery - rip me off by all means.....
I got the centres done locally but - at the end of the day anywhere that does shotblasting and powder coating will sort you out for around £20 a wheel....... (I got a good deal at £50 cos I use them a lot) They'd do another set but they'd almost certainly charge £70...... As they'd know that it wasn't for me......
You need to strip the rims down yourself but it doesn't take long
The polishing is easy - would it help if I wrote a guide?
I was lucky I had a set of wheels to roll around on while I did it all
If you want (and you weren't a million miles away from me) I could lend you a set of steelies and do it all for you in a week turnaround - provide your rims weren't horribly kerbed
£70 for the centres in colour of your choice - sandblasted and powder coated - very durable and easy clean finish
£40 for me to do the rim work - mirror finish - This is about 10 hrs work BTW
£20 for the tyre place to remove the tyres and re-fit once all the works been done.......
Or am I being a little sarcastic
