UPGRADING BCM 6R
Re: UPGRADING BCM 6R
benzinkopf wrote: Sat Jun 16, 2018 8:00 pm
ciclo wrote:
iichel wrote: Sat Jun 16, 2018 7:36 pm The german basically says:
wires or wire ?
mitgeliefertes
“ein......Kabel”
so it should be single wire.
btw. i think i bought the same AFS wiring from the same seller last time. As the wiring is made for LHD. i have to take out the terminal pins from the 26pin afs connector and switch the position from LHD to RHD, for one reason:
1) the length of wires provided is of coz opposite for Left and Right.
Ok, thanks for the warning. :wink:
ciclo wrote: Sat Jun 16, 2018 8:03 pm Thanks!
So the right one is .... https://www.ebay.com/itm/VW-Polo-V-6R-X ... xylpNTRTVy
Yes, but the item from tuning fanatics shop will get you the exact same wiring. :mrgreen: But they don't have the correct photo in their advertisement (they also write this in their description).
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
it may not bring any harm with the LHD or RHD as our bixenon leveling is just up & down, so it will still work. correct me if i’m wrong: but as there is adaptation settings to manually offset the motor position of each headlight, i believe it is necessary to correct that so the AFS module knows exactly the left and right headlight.
benzinkopf wrote: Sat Jun 16, 2018 8:15 pm it may not bring any harm with the LHD or RHD as our bixenon leveling is just up & down, so it will still work. correct me if i’m wrong: but as there is adaptation settings to manually offset the motor position of each headlight, i believe it is necessary to correct that so the AFS module knows exactly the left and right headlight.
I don't think it makes a difference, in ELSA there are no different wirings for left and right hand drive with respect to the AFS wiring.
I'd connect the headlights for a RHD polo the same way as a LHD.
govindsharma
Drives: polo 1.2 petrol HighLine
Post by govindsharma »
Thank you all of you sir for your kind help finally i have to buy these two wires.
1.VW Polo 6R ALWR Nachrüstung Kabelbaum Adapter cable harness. https://www.ebay.in/itm/170982304945?Vi ... SI:IN:1123
2.VW Polo V 6R Xenon Bi-Xenon Adapter Kabelbaum Kabel cable wiring https://www.ebay.in/itm/171296258148?Vi ... SI:IN:1123
Sir I have to take out 4 wire from BCM, 2 of cornering lights that i have to joint together and insert to SB54 a fuse and wire from 3rd connector of auto headlight red switch to SB54b fuse. and 2 cable of fog light drls which i had recently connected. ok.
And insert new 6 wires from T10 to T14 wiring to BCM only and leave the BCM intact.No wire from AFS to BCM.
All the wires of AFS is as under that i had understand via diagram that you had provided please check.
T26/2 - can high T32/28
T26/3 - can low T32/29
T26/7 - T4 AW/4 (Rear Axle)
T26/10 - T4 AW/2 (Rear Axle)
T26/11 - T4 AW/1 (Rear Axle)
T26/15 - T14B/1 (MX2 Right Headlight T14 Connector)
T26/20 - T14B/4 (MX2 Right Headlight T14 Connector)
T26/21 - T14B/2 (MX2 Right Headlight T14 Connector)
T26/22 - T14B/3 (MX2 Right Headlight T14 Connector)
T26/16 - T14A/3 (MX1 Left Headlight T14 Connector)
T26/17 - T14A/1 (MX1 Left Headlight T14 Connector)
T26/18 - T14A/4 (MX1 Left Headlight T14 Connector)
T26/19 - T14A/2 (MX1 Left Headlight T14 Connector)
T26/23 - SB13 (POWER)
T26/24 - earth.(EARTH)
Above wiring is ok for AFS and OEM BiXenon Headlights.
govindsharma
Sir I had found this kind of grommet under my car but it is tottaly sealed and one wire or pipe goes through it.Image
The cable you show I think belongs to the ABS sensor/rpm y and obviously the grommet is not the same as this,
Searching in ETKA:
If I select the Polo made in Europe this is the result,
If I select the Polo made in India this is the result,
Therefore, you must find another place to route the wires for AFS sensor.
I don't know if anyone in India did this work in its Polo 6R.
I think iichel used another route for the AFS sensor wires in his 6R.
Indeed I did, I used the grommet below the rear left seat.
Thanks for confirmation. :wink:
govindsharma
iichel Sir can you please show image of that place from where you routed AFS wire.
Thank you.
sure thing mate, here you go --> https://imgur.com/a/e6M59o2
govindsharma
Thank you I had seen this kind of hole is there in my car and that is covered by black groomet.
Yep the same here. I just punched through it and sealed it against water.
