RekinPoznan wrote: ... and add auto switch.
Best Regards Chriss
so, you need to make another wiring like this.
RekinPoznan
Drives: 6R
Post by RekinPoznan »
Hello
Ciclo in my model year A I have relay 331 in socket 4 ? and i must use (in your photo) small wire jumper , in this socket is two relays I must remowe left ? and connect pins 3 and 5 toghether.
in fuse box :
34B Split to new wire to T73a/62
39B cut original wire and split to T73b/2
59B cut original wire and split to T73a/2
New wire
39B ---> T73b/68
59B ---> T73A/63
Xenon range unit on the car connected tooday , waiting for leveling sensor only.
The wire T17/3 old now isolated is connected to old DRL (non led) in fog lamps , I use this wire with new relay for new instalation with auto switch (not needed to add new wire T73a/7 ---> T17/8 ---Ne wire Fuse 15A--- FOG) I planned use it with AUTO switch T10/5 ---> relay ---> FOG Right ?
Where is pin for xenon washer pump ? , i have planed wire for this.
Many thanks for understanding (better ask before replace instalation) and best regards Chriss
Good work so far!
All wiring corret, remove and bridge relay 331, pin 3 to 5 yes
New wire from T17/3 to T73b/29 (DRL input signal)
Washer supply: T10/1 or T17/12 (auto or non auto light switch)
RekinPoznan wrote:Hello
Pics:
viewtopic.php?f=56&t=68139#p508917
RekinPoznan wrote:
in fuse box :
New wire
39B ---> T73b/68
59B ---> T73A/63
https://drive.google.com/file/d/0B2nv91 ... RvU2c/view
https://drive.google.com/file/d/0B2nv91 ... d6MEE/view
RekinPoznan wrote: Where is pin for xenon washer pump ? , i have planed wire for this.
http://www.servimg.com/view/18943939/296
iichel wrote: Washer supply: T10/1 or T17/12 (auto or non auto light switch)
T17/11
RekinPoznan
Drives: 6R
Hello
Rewiring done , now DRL LED , and another functions works fine , many thanks for the support ;)
MichelKasapovic
Drives: Polo 1,2 tsi 90bhp 6r,6c
Post by MichelKasapovic »
Looks really nice. Need a R Line rear bumper. Can not find one with the diffuser on eBay. Only whole kits can be bought. Please help[emoji4]
New ones aren't overly expensive:
6R6 807 421 CH bumper
6R6 807 568 M diffusor
Thanks to you for sharing.
Please make a brief summary of what you've installed and is functioning properly. I do not remember the whole state (installations) of your 6R.
Bachecco
Drives: Polo 1.2
Post by Bachecco »
iichel wrote:try like this
[img]http://i.imgur.com/qP0OTBZ.png[/img]
Hi ciclo, I have adopted iichel's solution, and now everything is working perfectly. thanks to both of you.
One last question, where you have placed the resistors? because they really heat up!
Bachecco
Drives: Polo 1.2
Post by Bachecco »
On the metal of the body. So it can easily transfer heat
Bachecco
Drives: Polo 1.2
Post by Bachecco »
ok but how they attack? I can use the adhesive? because at that point I can't find holes where tie.
Inviato utilizzando Tapatalk
Duct tape
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
Hello, Fernando and everyone!
I've started a facelifting mod to 6C look. Additionally retrofit headlight washers and front PDC.
Next step is 6C headlights and grill retrofitting.
Now question is concerning headlight washer adaptation. What adaptation channels of 09 Cent.Eletr. change washer running time and frequency?
Locked
