i have recieved both and fitted the rear one, which is good and does indeed feel to of stiffened the rear up a little in the corners
i have not got round to fitting the front brace althoughit will fit with no clearence problems iv chosen not to do so as the polishing aint up to scratch and its a bit marked, so im picking up another at trax from them at the weekend
so if anyone sees someone carrying as mirror polished forge strut brace round at the show, this will most likely be me haha
Jeff GTi wrote:i have recieved both and fitted the rear one, which is good and does indeed feel to of stiffened the rear up a little in the corners
Jeff can i be a real pain in the but and get dimensions off you for both bars. the courier cmpanies are trying to do a dodgy on me and i need exact dimensions. Can the front strut bar be taken apart(ie split in 2). Thanks mate.
Sarah is dropping my rear strut brace off there for me to collect so I kinda quessed that'd be where your front one is. I'v had my front brace on for a while now and it does the trick Maybe see you there!
