strut brace question
im looking at getting upper and possibly lower braces for my polo gti
can anyone tell me what differences they have noticed from fitting
is one more effective than the other?
do they give noticable changes in steering feel or anything else?
cheers
jeff
cheers
jeff
Hey jeff
I got an upper forge strut brace fitted to my gti. Good quality and easy to fit but does mean taking it off again to change air filter. Once fitted my car is certainly more positive through corners, but understeer happened a bit sooner so i fitted a jabba rear arb and it works a treat now. I am running standard suspension as where i live has loads of speed bumps. I would think with your suspension set up the strut braces would work a treat. Where have you found to supply lower front brace?
- KennyPOLO_Gti
david burton
I only really notice a difference when pushing it. The front end feels marginaly tighter at low speeds but nothing major. I fitted the rear arb quite soon after the brace so didnt do too many miles with just brace on. The front brace and rear arb combo i got seems to suit my driving style well though. For best results i need to get a better suspension set up, but i dont want to lower it. Was thinking koni fsd?
- KennyPOLO_Gti
- KennyPOLO_Gti
BeezerDiesel
No, Jeff had another 1.8t Polo GTI before this one.KennyPOLO_Gti wrote:Can i ask what happened to your red polo gti? Was it the 1.6 16v?
You can also buy a SEAT Sport strut brace from SEAT dealers for the mk4 Ibiza that will probably also fit the Polo, and it's only about £40 - £50.
If you know someone with a mk4 Ibiza nearby it would be worth checking the measurements. I know it's a direct fit on the Fabia so the Polo probably is too (?)
These strut braces often come up for sale on seatcupra.net and briskoda
- KennyPOLO_Gti
- KennyPOLO_Gti
