Looney tuned project
mk4 glx 1.6
Re: Looney tuned project
Fitting a larger diameter front swaybar (I assume the H&R is) surely increases the understeer? I would have thought you would be better off with just a rear swaybar (ARB), or both front and rear, but certainly not just front?...Roadrunner... wrote:Chassis & Suspension :
KW variant 1
H&R front swaybar
Great looking car and nice (thoughtful) choice of modifications.
...Roadrunner...
First of all , thank you for your appreciation.mk4 glx 1.6 wrote:Fitting a larger diameter front swaybar (I assume the H&R is) surely increases the understeer? I would have thought you would be better off with just a rear swaybar (ARB), or both front and rear, but certainly not just front?...Roadrunner... wrote:Chassis & Suspension :
KW variant 1
H&R front swaybar
The H&R swaybar doesn't increase understeer. At least in my case, didn't. It isn't larger also, is is the same diameter as the original GTI one, but it has another shape. I needed the H&R swaybar, to eliminate the knocking that appeared on maximum steering to left or right, after lowering. The steering arms (that exit the steering case, and reach for the wheels) are touching the original swaybar when full steering to left or right is done, and produces a knocking sound. I'm sure that all of lowered GTI have that sound. This is were it camed from. Whit the H&R swaybar, the steering arm gets right around the swaybar, so no knocking
I have attached 2 pictures, first with the original swaybar, the second with the aftermarket one.
...Roadrunner...
- whitegtipolo
...Roadrunner...
The standard N75 is very good for standard engines. Mine is remaped, and the standard valve is out of range working with increased turbo boost.whitegtipolo wrote:how does the valve make so much differnce, if so how come its not fitted standard??
The J valve is working very well with higher boost levels... Get it ?
- whitegtipolo
I get what you mean getting mine remapped shortly off www.more-bhp.com vag remappers , how much is the boost valve n part number ??...Roadrunner... wrote:The standard N75 is very good for standard engines. Mine is remaped, and the standard valve is out of range working with increased turbo boost.whitegtipolo wrote:how does the valve make so much differnce, if so how come its not fitted standard??
