right brake lines???pic pg 3
Re: Gti breaks to G60 (whats needed)
there some nice pics guys thankyou sorry took me so long been at work .... in the setup i bought off a chap on ebay the discs are drilled tim but thinkin of sellin cause i want these discs called nitrac discs my friend has them on his focus st 170 had them on one year and there is no lip at all its amazing really there frozen to stupid minus degrees in temps so weel see and for pads i think either mintex extreme or ferodo ds pads lol tomo i thought you would have 4 pots on that weapon !!! lol is the disc on the 3rd picture (behind the rx1's) backwards lol or is just me
lol
- Tim_GTi
- Post Whore
Your right, that disc IS backwards! That's Mouse's car.
oh dear i hope he realised
its perfectly fine to run the discs that way, thats how mine are on my 20v......obviously increases wear on the pads but also better breaking
- Tim_GTi
- Post Whore
How does it increase breaking?
by a very small amount, there is higher levels of friction as the grooves are pointing the opposite direction
well you learn somethin new every day, i think ill be using mine the right way though ....
hello again people i have my breaks now
and it looks like a good set of pagid fast road pads dont know who the disks are made by but there exsacly the same disks as the 2nd pic 3 holes then 2 holes then 3 holes ....anyway the question is i ordered some polo 6n2 goodridge braided lines... they screw in fine to the g60 caliper but there is about a 1 inch long length of metal untill the bolt which means it wont be secured by anything, iv done some searching about and read that gti brake line are slighty diffrent to g60 style ones as they use a different clip ? just wondering if any of you lot have a g60 setup with braided lines what did you use ???? ill put some pics up in a min and you lot see if it looks right ? help appriciated again as its snowing heavily again i cant go outside and have a look else i would of lol
so heres my problem then is that the right brake line for a 6n2 style clip(if there is such a thing) lol or have i totally got the wrong ones ? I ask this as the braided lines that came with the setup ( cut off the car) the nut on the brake line sat flush to the body of the caliper an had a thing called a 'crush' washer to seal it...?
cheers guys
Re: g60 brakes are here, right brake lines???pg3
TTT with this one guys as i need to know lol else i wont be able to send them back !!
Is that a rear hose?
Looks like the kit included hoses to suit the drums.... Drum hoses usually have a flatter end to them as apposed to a pointy male end as per the disk callipers
no mate that is a front the two rear ones that come in the kit are two female ends....it says on the box 'polo 6n2' and said on venommotorsports site that it was for a gti ??? totally wrong im guessing then havnt had chance to look on car yet as the weather is shocking like ...
Re: right brake lines???pic pg 3
anyone???
