Edi30 wrote:
Sorry I got this wrong the sensor built into the screen of my Polo looks identical to the sensor on my Golf which has auto lights Perhaps it's just a new switch and a reprogram to enable auto coming/leaving home lights? Can any one confirm if the dusk sensor is built into the rain sensor as I think it is?
Has anyone solved this? can't find anything on the net.
Theirs auto light kits available on eBay And seat do one for the Ibiza which bypass the need for an auto light switch If your that keen on them
Ive not found a solution for coming home lights
i managed it with the guide i posted did you find the bit where you had to change it to Australia ? once you have done that its quite simple with the guide i posted
Teardrop wipe
Speed dependant wipers (they drop down the next lowest setting when you stop)
and if its possible turn off the day time running lights front & rear
bennyboy wrote:can any one do a step by step guide on this plz.
Teardrop wipe
DLRs can be switched of with the lights stalk - it's in the handbook. They are there for a reason though...
Teardrop wipe
Thanks for the heads up i suppose i will have to read the handbook now .
