Idle Control Value
Idle Control Value
I think you might of been too impatient
vcds is the best way though. Glad you're sorted mate
Re: Idle Control Value
benmkiv wrote:I think you might of been too impatientvcds is the best way though. Glad you're sorted mate
Although I am not sure if the throttle alignment has solved it as I havent started the car as yet. Just wanna let it cool down properly and then
start her up when she is at high revs. This technique is probably meaningless but just wanna make sure the hesitation is gone
Btw looking at the video in my previous post, can you tell me it was the correct technique??????
Idle Control Value
Certainly looks like it mate
Idle Control Value
I did warn you! Lolz I said disconnect the electric solenoid for the throttle flap. I think you have been to quick to start the car as others have said. I've cleaned my throttle body and had 0 problems.POLOZ wrote:A man why did i move the butterfly valvebenmkiv wrote:But largely likely it may be incorrectly aligned throttle body. It was also a bad move to move the butterfly valve when cleaning because this can damage the tb. Best thing is to get it to someone who knows best I'm afraid to say. With the turbo engines it's worth the money I'm afraid mannobody warned me about that
During cold starts the car always had high revs but and you can hear the revs settling down after 1 min from start. When it is settling down, the engine feels hesistant and the whole car shakes if u know what i mean? Once the revs calm down, the idle is smooth
Yes!JoshGTI wrote: I did warn you! Lolz I said disconnect the electric solenoid for the throttle flap. I think you have been to quick to start the car as others have said. I've cleaned my throttle body and had 0 problems.
Anyways good news started the car this morning and it wasnt being hesitant or feel like the car was gasping for airRemove intercooler to TB hose. Remove solenoid motor at the back of the throttle body ( so you dot damage motor when moving throttle flap) I think this is held with a clip, I'm sure you could figure it out by looking at it.
Hopefully I didnt do any major damage to the mentioned solenoid motor
the rev counter needle slightly moving. Dunno if this is to do with the TB?
Idle Control Value
Good news, for further reference to others I believe the car should be left in acc position for at least 15 mins
AND dont move the butterfly valve unless the solenoid motor is removed. But If it is me, I'd not move the butterfly valvebenmkiv wrote:Good news, for further reference to others I believe the car should be left in acc position for at least 15 mins
Also benmkiv, is the rev needle moving a wee bit normal? I mean it only moves a few mm up and down during idle.
Idle Control Value
Hard to tell. I never paid attention as long as it's not up and down by a couple hundred should think it'd be ok mate the reason we did the TT was at idle it was pulsing between 800 and 1300rpm. if you have this problem never look in the Haynes manual fault finding you'll cack your pants "loss of compression on one or mew cylinders" xD
